Can't locate ZoneMinder/Base.pm Error while trying to upgrade database.
Posted: Sun Jan 24, 2016 12:44 am
Trying to upgrade ZM from 1.28.1 to 1.29. It installed with no errors but when I try to upgrade the database I get this error. This is on a Slackware box running Current-64.
Not sure where to get ZoneMinder::Base module from. I'm assuming that's a perl module.
Can't locate ZoneMinder/Base.pm in @INC (you may need to install the ZoneMinder::Base module) (@INC contains: /usr/local/lib/perl5/site_perl/5.22.1/x86_64-linux /usr/local/lib/perl5/site_perl/5.22.1 /usr/local/lib/perl5/5.22.1/x86_64-linux /usr/local/lib/perl5/5.22.1 .) at /usr/local/bin/zmupdate.pl line 70.
BEGIN failed--compilation aborted at /usr/local/bin/zmupdate.pl line 70.
