Console display in XML
princess_m
Post by princess_m »
"This XML file does not appear to have any style information associated with it."
How might I correct this error message in 'localhost/zm'?
Ubuntu 15.10 running on a Revo. ZM has worked in the past but this is updated software, probably built from source ( have tried various ways to install a current ZM, most of them curl up and die at some point).
Many thanks.
Re: Console display in XML
We can't possibly give you a detailed answer with what little you've told us.
Start by reading forum rules, which describe how to ask for help:
viewtopic.php?f=32&t=23808
Your likely next step will be to read the appropriate Ubuntu "easy way" documentation found in the Wiki.
asker
Post by asker »
In the event you are stuck with this message when you try and view your web console, try to put in the following url
http://your.server.com/zm/?skin=classic
Please read before posting:
ES docs
zmNinja docs
princess_m
That's what it needed.
http://localhost/zm/?skin=classic
results in the XML code being translated to the console display we all know and love, now I can move on to configuring ZM again.
Many thanks for bothering to respond to my question, I appreciate it.
In this case "Asker" is the "Answerer" - thanks.
