Error streaming video on web
NeKRoN
Post by NeKRoN »
Hi. After update to v1.29.0 i cant see stream from camera on web. But i can see how they work and write captures.
And after update, in log have new error, when i try open montage:
"Attempt to fetch string value for ZM_OPT_USE_GOOG_RECAPTCHA, actual type is boolean. Try running 'zmupdate.pl -f' to reload config."
I try zmupdate.pl -f, but its not result. Help!
Re: Error streaming video on web
Please post the output of zmupdate.pl. Also, it must be run as root, so make sure you are doing
sudo zmupdate.pl
NeKRoN
Post by NeKRoN »
iconnor wrote:Please post the output of zmupdate.pl. Also, it must be run as root, so make sure you are doing
sudo zmupdate.pl
"Database already at version 1.29.0, update aborted."
And zmupdate.pl -f
Freshening configuration in database
Loading config from DB
Saving config to DB
There are a couple of "settings" that need to be changed depending upon your OS distro. We can't guess which version of Linux you are using...
NeKRoN
Post by NeKRoN »
bbunge wrote:There are a couple of "settings" that need to be changed depending upon your OS distro. We can't guess which version of Linux you are using...
3.16.0-30-generic #40~14.04.1-Ubuntu
This will happen if you try to run "sudo zmupdate.pl -f" and it can't get a lock on the database (i.e. zoneminder is still running and holding the dB open).
After running sudo zmupdate.pl -f, if you still see the same message in your logs, then the operation was not successful.
You need to figure out what is preventing zmupdate.pl from getting a lock on your database.
NeKRoN
Post by NeKRoN »
I stopped zoneminder and apache, zmupdate.pl -f again and... nothing.
/In start i update base with zmupdate and its successful.
tester
Post by tester »
same problem after the recent update.
zmupdate run successful.
Looks like cameras are capturing but no stream in monitor preview. There are errors in log like this:
socket_sendto( /var/run/zm/zms-559798s.sock ) failed: No such file or directory
getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-559798w.sock ) failed: Address already in use - checkStreamForErrors()
This is Linux UBUNTU_14.04 3.13.0-78-generic #122-Ubuntu SMP Mon Feb 1 23:11:33 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
What should I do to fix? Thanks
tester
Post by tester »
again me))
read carefully all instructions at https://wiki.zoneminder.com/Common_Issu ... untu_14.04
especially in section: Ubuntu 14.04 - ZM 1.26.5 or later to 1.29.0 or the latest PPA version
and repeat it again, though I thought I already did it before.
seems all is fine now.
THANKS my friends!)
tester wrote:same problem after the recent update.
This error has nothing to do with the original post and should have gone in its own thread.
This means you've got something else running on your system that has already created the same socket. That usually means you've got leftovers from a previous session of zoneminder still running. You could go through your process list, find and kill them all, but a reboot might be simpler.
juggalo818
Post by juggalo818 »
i have this same problem cameras are blinking info in console are green but there is no video here is my log .... i am useing ubuntu 15.10 and ZoneMinder v1.29.0 please help
Updated: Wed 6th Jul, 7:01pm State: alert Total: 1008 Available: 1008 Displaying: 200
Filter log - Component Server PID Level File Line Reset
Date/Time
Component Server PID Level Message File Line
2016-07-06 18:55:00.410287 web_php 2282 ERR socket_sendto( /var/run/zm/zms-440605s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-07-06 18:54:49.845651 web_js 1361 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-07-06 18:53:49.911121 zmc_m1 1734 INF Monitor-1: 12000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:53:49.785692 zmc_m1 1843 ERR Unable to open input 192.168.0.69/img/video.mjpeg due to: No such file or directory zm_ffmpeg_camera.cpp 271
2016-07-06 18:53:49.014695 zmc_m1 1734 INF Monitor-1: 11000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:48.113262 zmc_m1 1734 INF Monitor-1: 10000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:47.235403 zmc_m1 1734 INF Monitor-1: 9000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:46.399384 zmc_m1 1734 INF Monitor-1: 8000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:45.432770 zmc_m1 1734 INF Monitor-1: 7000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:44.577000 zmc_m1 1734 INF Monitor-1: 6000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:43.670104 zmc_m1 1734 INF Monitor-1: 5000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:42.420570 zmc_m1 1734 INF Monitor-1: 4000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:41.452619 zmc_m1 1734 INF Monitor-1: 3000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:40.785694 zmc_m1 1734 INF Monitor-1: 2000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:53:40.025148 zmc_m1 1734 INF Monitor-1: 1000 - Capturing at 500.00 fps zm_monitor.cpp 3131
2016-07-06 18:53:39.142715 zmc_m1 1734 ERR Unable to open input 192.168.0.69/img/video.mjpeg due to: No such file or directory zm_ffmpeg_camera.cpp 271
2016-07-06 18:53:38.541706 zmc_m1 1734 INF Priming capture from 192.168.0.69/img/video.mjpeg zm_ffmpeg_camera.cpp 104
2016-07-06 18:53:38.288390 zmc_m1 1734 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-07-06 18:53:37.975642 undef 1734 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-06 18:53:37.716390 zmdc 1388 INF 'zmc -m 1' starting at 16/07/06 15:53:37, pid = 1734 zmdc.pl
2016-07-06 18:53:37.716390 zmdc 1734 INF 'zmc -m 1' started at 16/07/06 15:53:37 zmdc.pl
2016-07-06 18:53:37.645820 zmdc 1388 INF Starting pending process, zmc -m 1 zmdc.pl
2016-07-06 18:53:37.578720 zmdc 1388 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-07-06 18:53:36.187137 undef 1574 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-06 18:53:30.002410 zmwatch 1596 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-07-06 18:53:29.909580 zmdc 1388 INF 'zmupdate.pl -c' starting at 16/07/06 15:53:29, pid = 1603 zmdc.pl
2016-07-06 18:53:29.909580 zmdc 1603 INF 'zmupdate.pl -c' started at 16/07/06 15:53:29 zmdc.pl
2016-07-06 18:53:29.888310 zmwatch 1596 INF Watchdog starting zmwatch.pl
2016-07-06 18:53:29.561610 zmdc 1596 INF 'zmwatch.pl' started at 16/07/06 15:53:29 zmdc.pl
2016-07-06 18:53:29.559930 zmdc 1388 INF 'zmwatch.pl' starting at 16/07/06 15:53:29, pid = 1596 zmdc.pl
2016-07-06 18:53:29.402230 zmfilter 1578 INF Scanning for events zmfilter.pl
2016-07-06 18:53:29.090410 zmdc 1583 INF 'zmaudit.pl -c' started at 16/07/06 15:53:29 zmdc.pl
2016-07-06 18:53:29.083270 zmdc 1388 INF 'zmaudit.pl -c' starting at 16/07/06 15:53:29, pid = 1583 zmdc.pl
2016-07-06 18:53:28.613350 zmdc 1578 INF 'zmfilter.pl' started at 16/07/06 15:53:28 zmdc.pl
2016-07-06 18:53:28.613350 zmdc 1388 INF 'zmfilter.pl' starting at 16/07/06 15:53:28, pid = 1578 zmdc.pl
2016-07-06 18:53:28.251280 zmdc 1574 INF 'zmc -m 1' started at 16/07/06 15:53:28 zmdc.pl
2016-07-06 18:53:28.251270 zmdc 1388 INF 'zmc -m 1' starting at 16/07/06 15:53:28, pid = 1574 zmdc.pl
2016-07-06 18:53:27.922590 zmpkg 1367 INF Starting up services zmpkg.pl
2016-07-06 18:53:24.915750 zmdc 1388 INF Server starting at 16/07/06 15:53:24 zmdc.pl
2016-07-06 18:53:24.386190 zmpkg 1367 INF Command: start zmpkg.pl
2016-07-06 18:53:24.009790 zmpkg 1367 INF Sanity checking States table... zmpkg.pl
2016-07-06 18:52:12.989460 zmdc 1362 INF Server shutdown at 16/07/06 15:52:12 zmdc.pl
2016-07-06 18:52:02.731380 zmdc 1362 INF 'zmc -m 1' exited normally zmdc.pl
2016-07-06 18:52:01.475240 zmdc 1362 INF 'zmc -m 1' sending stop to pid 1933 at 16/07/06 15:52:01 zmdc.pl
2016-07-06 18:52:01.370080 zmdc 1362 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-07-06 18:52:01.299860 zmdc 1362 INF 'zmfilter.pl' sending stop to pid 1556 at 16/07/06 15:52:01 zmdc.pl
2016-07-06 18:52:01.226560 zmdc 1362 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-07-06 18:52:01.149600 zmdc 1362 INF 'zmaudit.pl -c' sending stop to pid 1566 at 16/07/06 15:52:01 zmdc.pl
2016-07-06 18:52:01.075660 zmdc 1362 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-07-06 18:52:00.998460 zmdc 1362 INF 'zmupdate.pl -c' sending stop to pid 1605 at 16/07/06 15:52:00 zmdc.pl
2016-07-06 18:52:00.942200 zmdc 1362 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-07-06 18:52:00.866090 zmdc 1362 INF 'zmwatch.pl' sending stop to pid 1592 at 16/07/06 15:52:00 zmdc.pl
2016-07-06 18:51:59.670670 zmpkg 2326 INF Command: stop zmpkg.pl
2016-07-06 18:51:59.318590 zmpkg 2326 INF Sanity checking States table... zmpkg.pl
2016-07-06 18:50:13.183688 zmc_m1 1933 INF Monitor-1: 15000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:12.541335 zmc_m1 1933 INF Monitor-1: 14000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:50:12.343891 zmc_m1 2068 ERR Unable to open input 192.168.0.69/img/video.mjpeg due to: No such file or directory zm_ffmpeg_camera.cpp 271
2016-07-06 18:50:12.163173 zmc_m1 1933 INF Monitor-1: 13000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:11.412138 zmc_m1 1933 INF Monitor-1: 12000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:10.693528 zmc_m1 1933 INF Monitor-1: 11000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:50:10.108558 zmc_m1 1933 INF Monitor-1: 10000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:09.474899 zmc_m1 1933 INF Monitor-1: 9000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:08.827823 zmc_m1 1933 INF Monitor-1: 8000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:50:08.395332 zmc_m1 1933 INF Monitor-1: 7000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:07.724717 zmc_m1 1933 INF Monitor-1: 6000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:06.931768 zmc_m1 1933 INF Monitor-1: 5000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:05.872724 zmc_m1 1933 INF Monitor-1: 4000 - Capturing at inf fps zm_monitor.cpp 3131
2016-07-06 18:50:05.085789 zmc_m1 1933 INF Monitor-1: 3000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:04.338775 zmc_m1 1933 INF Monitor-1: 2000 - Capturing at 1000.00 fps zm_monitor.cpp 3131
2016-07-06 18:50:03.603536 zmc_m1 1933 INF Monitor-1: 1000 - Capturing at 333.33 fps zm_monitor.cpp 3131
2016-07-06 18:50:02.732290 zmc_m1 1933 ERR Unable to open input 192.168.0.69/img/video.mjpeg due to: No such file or directory zm_ffmpeg_camera.cpp 271
2016-07-06 18:50:01.915992 zmc_m1 1933 INF Priming capture from 192.168.0.69/img/video.mjpeg zm_ffmpeg_camera.cpp 104
2016-07-06 18:50:00.900005 zmc_m1 1933 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-07-06 18:49:59.889840 undef 1933 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-06 18:49:58.614780 zmdc 1933 INF 'zmc -m 1' started at 16/07/06 15:49:58 zmdc.pl
2016-07-06 18:49:58.614740 zmdc 1362 INF 'zmc -m 1' starting at 16/07/06 15:49:58, pid = 1933 zmdc.pl
2016-07-06 18:49:58.145290 zmdc 1362 INF Starting pending process, zmc -m 1 zmdc.pl
2016-07-06 18:49:57.651580 zmdc 1362 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-07-06 18:49:54.326410 undef 1538 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-06 18:49:45.583630 zmwatch 1592 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-07-06 18:49:45.477320 zmdc 1605 INF 'zmupdate.pl -c' started at 16/07/06 15:49:45 zmdc.pl
2016-07-06 18:49:45.477310 zmdc 1362 INF 'zmupdate.pl -c' starting at 16/07/06 15:49:45, pid = 1605 zmdc.pl
2016-07-06 18:49:45.455400 zmwatch 1592 INF Watchdog starting zmwatch.pl
2016-07-06 18:49:45.010070 zmdc 1592 INF 'zmwatch.pl' started at 16/07/06 15:49:45 zmdc.pl
2016-07-06 18:49:45.008170 zmdc 1362 INF 'zmwatch.pl' starting at 16/07/06 15:49:45, pid = 1592 zmdc.pl
2016-07-06 18:49:44.896830 zmfilter 1556 INF Scanning for events zmfilter.pl
2016-07-06 18:49:44.465790 zmdc 1566 INF 'zmaudit.pl -c' started at 16/07/06 15:49:44 zmdc.pl
2016-07-06 18:49:44.465720 zmdc 1362 INF 'zmaudit.pl -c' starting at 16/07/06 15:49:44, pid = 1566 zmdc.pl
2016-07-06 18:49:44.030320 zmdc 1362 INF 'zmfilter.pl' starting at 16/07/06 15:49:44, pid = 1556 zmdc.pl
2016-07-06 18:49:44.030320 zmdc 1556 INF 'zmfilter.pl' started at 16/07/06 15:49:44 zmdc.pl
2016-07-06 18:49:43.716500 zmdc 1538 INF 'zmc -m 1' started at 16/07/06 15:49:43 zmdc.pl
2016-07-06 18:49:43.716360 zmdc 1362 INF 'zmc -m 1' starting at 16/07/06 15:49:43, pid = 1538 zmdc.pl
2016-07-06 18:49:43.423130 zmpkg 1335 INF Starting up services zmpkg.pl
SteveGilvarry
Post by SteveGilvarry »
It doesn't like the url you are using for the camera.
juggalo818
that is the the url the other system has the only differences in the system is this one is v1.29.1 and the working one is v1.28.1
juggalo818
i typed in another camera and now i get this ....
2016-07-06 21:18:38.091208 web_js 2676 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-07-06 21:18:37.982378 web_php 2676 ERR socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2375
2016-07-06 21:18:26.025460 web_js 2246 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-07-06 21:18:25.807957 web_php 2246 ERR socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2375
2016-07-06 21:18:13.799492 web_js 2246 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-07-06 21:18:13.657113 web_php 2246 ERR socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2375
2016-07-06 21:18:01.657382 web_js 1393 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-07-06 21:18:01.488545 web_php 1393 ERR socket_sendto( /var/run/zm/zms-408800s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2375
2016-07-06 21:17:54.886390 web_js 2188 WAR Adjusting to minimum width when getting popup size for tag 'watch' - getPopupSize()
2016-07-06 21:17:49.568531 zma_m1 2666 INF In mode 3/1, warming up zma.cpp 142
2016-07-06 21:17:48.890542 zmc_m1 2662 WAR Option rtsp_transport not recognized by ffmpeg zm_ffmpeg_camera.cpp 281
2016-07-06 21:17:48.522507 zma_m1 2666 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-07-06 21:17:48.414164 zmc_m1 2662 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp
