Missing README from CentOS zmrepo rpm...
Tantamount
Post by Tantamount »
Per the dropdown instructions for CentOS 7 (https://zmrepo.zoneminder.com/), I followed these instructions on a clean minimal install of CentOS 7:
wget http://zmrepo.zoneminder.com/el/7/x86_64/zmrepo-7-6.el7.centos.noarch.rpm
sudo yum install --nogpgcheck zmrepo-7-6.el7.centos.noarch.rpm
sudo yum install zoneminder
less /usr/share/doc/zoneminder-*/README.Centos7
Everything seemed to install correctly, and I saw the instructions to read the README file when the zoneminder rpm was installed:
VERY IMPORTANT: Before starting ZoneMinder, read README.Centos7 to finish the
installation or upgrade!
The README file is located here: /usr/share/doc/zoneminder-1.29.0.
  Verifying  : zoneminder-1.29.0-3.el7.centos.x86_64        1/1
Installed:
  zoneminder.x86_64 0:1.29.0-3.el7.centos
Complete!
However, no readme file exists?
[root@1fe5d6c5993f zoneminder-1.29.0]# cd /usr/share/doc/zoneminder-1.29.0/
[root@1fe5d6c5993f zoneminder-1.29.0]# ls -la
total 12
drwxr-xr-x  3 root root 4096 Feb  7 17:29 .
drwxr-xr-x 32 root root 4096 Feb  7 17:29 ..
drwxr-xr-x  2 root root 4096 Feb  4 23:30 jscalendar-doc
If I run rpm -Vvvv zoneminder, it shows that the files aren't installed:
[root@1fe5d6c5993f zoneminder-1.29.0]# rpm -vV zoneminder|grep "README"
.........  d /usr/share/doc/zoneminder-1.29.0/README.Centos7 (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/README.https (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/README.md (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/README (not installed)
.........    /usr/share/zoneminder/www/api/README.md
.........    /usr/share/zoneminder/www/api/app/Plugin/Crud/README.md
.........    /usr/share/zoneminder/www/api/app/vendor/composer/installers/README.md
Anyone have any ideas what's going on here? It looks like a lot of files weren't installed:
[root@1fe5d6c5993f zoneminder-1.29.0]# rpm -vV zoneminder|grep "not installed"
.........  d /usr/share/doc/zoneminder-1.29.0/AUTHORS (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/BUGS (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/COPYING (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/ChangeLog (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/LICENSE (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/NEWS (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/bugtest-hidden-selects.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/calendar.php (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/dayinfo.html (not installed)
.........    /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/html/field-button.jpg (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/html/reference-Z-S.css (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/html/reference.css (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/html/reference.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/index.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/multiple-dates.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/reference.pdf (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/release-notes.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/simple-1.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/simple-2.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/simple-3.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/test-position.html (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/jscalendar-doc/test.php (not installed)
.........  d /usr/share/doc/zoneminder-1.29.0/local_zoneminder.te (not installed)
.........  d /usr/share/man/man3/ZoneMinder.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Base.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Config.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::ConfigAdmin.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::ConfigData.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::3S.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::AxisV2.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI8608W_Y2k.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI8620_Y2k.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI8908W.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI8918W.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI9821W_Y2k.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::FI9831W.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::M8640.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::Ncs370.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::PanasonicIP.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::PelcoD.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::PelcoP.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::SPP1802SWPTZ.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::SkyIPCam7xx.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::TVIP862.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::Toshiba_IK_WB11A.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::Visca.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::Wanscam.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Control::mjpgStreamer.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Database.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::General.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Logger.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Memory.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Server.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::File.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::Handle.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::Inet.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::Serial.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::Spawning.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Channel::Unix.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Connection.3pm.gz (not installed)
.........  d /usr/share/man/man3/ZoneMinder::Trigger::Connection::Example.3pm.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zma.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmaudit.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmc.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmcamtool.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmcontrol.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmdc.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmf.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmfilter.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmpkg.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmstreamer.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmsystemctl.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmtrack.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmtrigger.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmu.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmupdate.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmvideo.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmwatch.pl.8.gz (not installed)
.........  d /usr/share/man/man8/zoneminder-zmx10.pl.8.gz (not installed)
3 ReoLink RLC-410
2 Annke NC800
Kubernetes 1.22.6 statefulset of 5 Ubuntu 20.04 pods using iconnor's repository
ZoneMinder Version 1.36.12
Re: Missing README from CentOS zmrepo rpm...
I have run that setup several times and the Readme files were there every time. I did, however, use WinSCP to find the file.
bb
Tantamount
The fact that the files show as "not installed" instead of "missing" suggests there's some type of rpm install check that is gracefully failing, correct? The rpm install script is deciding not to install those files for some reason.
3 ReoLink RLC-410
2 Annke NC800
Honestly, I do not know. I've been working with the RH distros for about a week (just for fun). The package maintainer should chime in to help. I am currently loading a Ubuntu 15.10 server with Mariadb 10.1.11 and ZM 1.29.0... just to see how it works...
bb
No idea what is going on, and I'm not even sure it is possible to install an rpm with a failure like that during a normal operation.
In each case that I've seen, if yum/rpm runs into a problem during the installation, it aborts completely w/o installing anything. The only way I know how to get one's system into a state like that is to control-C or reboot midway through the installation.
My only advice is uninstall completely and start over.
- uninstall the zoneminder rpm
- inspect every folder on your fielsystem previously containing "not installed" files, and make sure the folder is deleted.
- Yum install zoneminder again. This time watch the output for any errors or any other out of the ordinary messages.
If you still have issues, then copy and paste the entire build output, starting with the command you entered into the command prompt, into this thread.
Tantamount
Fascinating. No, there were no issues when the rpm installed itself (No reboots, no errors), and yeah, I tried uninstalling and re-installing. You can see in my previous post that it reported "Complete!", and again running the rpm verify command comes up clean. Only when I add the extra -v for verbosity does it show that the files weren't installed.
Well, I'm not going to worry about it. I found the readme online.
3 ReoLink RLC-410
2 Annke NC800
Things like this can come back to bite you later, like during the next upgrade.
Its your choice if you don't want pursue this any further.
If you do, we need to see the entire output from yum, including the initial command entered into the command line, and not just the end of the output. Finding the cause is going to require real data. Even if the output looks fine to you, it doesn't hurt to have a second set of eyes look at it.
This guy seems to report a similar problem installing an rpm:
http://stackoverflow.com/questions/2820 ... -all-files
It is unclear what the root cause was in his case.
This appears to be relevant:
http://superuser.com/questions/784451/c ... -doc-files
You did not state if you were running in a Docker container, but even if you are not, please check /etc/rpm/macros.imgcreate and /etc/yum.conf for any excludedocs or nodocs parameters.
