ZM console won't run
Danzi
Post by Danzi »
MY PC did a software upgrade and is now hosed for ZM
The Console log in screen comes up, I can log in but this error comes up-
SQL-ERR 'SQLSTATE[42S02]: Base table or view not found: 1146 Table 'zm.Servers' doesn't exist', statement was 'SELECT * FROM Servers'
I tried doing a restore form backup but no joy.
What do I do ??
Thanks Dan
Re: ZM console won't run
Check the upgrade instructions in the WIKI. You may get lucky! Else purge ZM and start over.
