ZoneMinder, v1.29.0 on a Ubuntu box with ZmNinji as remote client
I have an existing hard wired camera/dvr setup that feeds into Webcamxp via a USB capture device. I am moving to IP cams that I run on ZM. Would like to setup a ZM monitor with my existing Webcamxp feed as the source so I can view all cameras in just ZM until I totally switch over. Can not figure out the correct setup in ZM. I need a snapshot jpg setup.
The image url is http://xxxx:8085/cam_2.jpg
Thanks.
Webcamxp Output as a Source
- Webcamxp source image
- cams.jpg (160.25 KiB) Viewed 1848 times
