Page 1 of 1
API Howto for Debian 1.28
Posted: Sat Feb 13, 2016 4:25 pm
by asker
For folks looking to get access to APIs on Debian, please follow this guide till some version of 1.29 is released.
It's been tested to work with Debian 8 running zm 1.28.1
https://github.com/pliablepixels/zmNinj ... -ZM-1.28.x
Re: API Howto for Debian 1.28
Posted: Mon Feb 15, 2016 7:58 am
by Markymark
Hi asker,
many thanks for your effort!
Debian "Wheezy" installation following
this documentation.
Could follow your instructions, except that the directory "/usr/share/zoneminder/www" is not present. The relevant files seem to be directly in "/usr/share/zoneminder". So I added "/usr/share/zoneminder/api" instead.
After restarting Apache the following red line occured:
"URL rewriting is not properly configured on your server. 1) Help me configure it 2) I don't / can't use URL rewriting"
I followed the same instructions with the directory as mentioned (/usr/share/zoneminder/www/api) - but with the same result. I stopped to fumble around at this point to keep things clean.
Any help apprechiated.
Rgrds,
Mark
Posted: Mon Feb 15, 2016 4:12 pm
by asker
Can you use Jessie/8 instead? Wheezy/7 uses an older version of apache and the instructions you are using are actually for 1.28 but you are building 1.29, so its a bit of a mess.
Posted: Mon Feb 15, 2016 5:05 pm
by Markymark
No, it is an existing installation v1.28.100. I would be happy to upgrade to 1.29, but as far as I understood there is no proved upgrade path known at the moment.
Honestly I would hesitate to upgrade to Jessie because I have a very stable configuration up and running. At the moment the API would be the only reason to switch to Jessie. As I do not oversee the effort to get the API running with Wheezy/1.28.100 it is hard for me to make a reasonable decision. Could you give me any advice?
Rgrds,
Mark
Posted: Mon Feb 15, 2016 7:57 pm
by asker
The
link you posted for instructions does a git clone
https://github.com/ZoneMinder/ZoneMinder.git from the master branch - thats 1.29 today. So if you followed those instructions recently, you should be running 1.29 not 1.28.100
I'm not suggesting 1.29 on Jesse. I'm suggesting 1.28 on Jesse which is stable and official.
https://wiki.zoneminder.com/Debian_8.1_ ... e_Easy_Way
Once you do that, you can use my API package for Jesse.
However, I totally understand why you might not want to move. I'm not a debian guy so I don't know what is good/what is not - that's a call you have to make. I took at quick look at Wheezy and it seems that distro runs an older version of Apache, plus, the ZM in that distro installs into /usr/share/zoneminder instead of /usr/share/zoneminder/www -> which is probably why the API package is not working - I don't quite have the time right now to investigate what all to change for Wheezy
Posted: Mon Feb 15, 2016 8:29 pm
by Markymark
I installed ZM several month ago - I think in mid 2015. This is definitively 1.28.100 as far as I can see.
OK, so far I did not get the idea that the API package is exclusivly for Jessie.
Asker, this is perfectly all right for me. If this is a singular problem it makes no sense to spend time on it. Thanks anyway.
Rgrds,
Mark
Posted: Mon Feb 22, 2016 7:12 pm
by Markymark
@asker,
I spent some time today trying to get the API running with Wheezy.
From what I understand there should be three '.htaccess' files arround - one in cake root directory, one in app root directory and one in webroot directory. I could not find the one that should be located in the cake root directory - which is accoring to my understanding /usr/share/zoneminder/api/lib/Cake.
Could that be (part of) the problem?
Rgrds,
Mark
P.S.: I already tried to add .htaccess at that location but that does not solve the issue. Maybe this is the right direction anyway.
Posted: Fri Mar 18, 2016 11:25 pm
by videoboom
I have the same problem on Raspberry with Debian
URL rewriting is not properly configured on your server... and API not works
Did u solve ?
Posted: Sat Mar 19, 2016 7:01 am
by Markymark
@videobroom,
I finally startet with a new installation of Ubuntu Trusty and ZM1.29 - and that did the trick. You might get it up and running with 'older' versions. But what have you gained at last - apart from experience? You can migrate the database with a few steps:
viewtopic.php?f=34&t=24405&p=93230&hilit=migrate#p93215
Rgrds, Mark
Posted: Sat Mar 19, 2016 7:46 am
by videoboom
Oh Thanks, i'm on Raspberry PI ... i will try
