I've been suffering with a problem for quite some time and I've isolated it down to one issue, but I don't understand the cause.
I'm running Gentoo, ZM 1.28.1 and its working great on an mpeg4 1080P camera, as long as I allow the events to be stored on my ssd in the same folder as the zoneminder www data.
If I change events & images to be symlinks, or if I mount my raid array in place, then the recordings stop working, disappear and I can't get them back.
I've tried this over and over again and every time I use symlinks or use a mount --bind, the recordings stop working.
I figure, since I spin my own kernel, there is a kernel setting to do with filesystems that must be set for zoneminder to function, but I have no idea what it is.
Has anyone dealt with this?
I'll trawl through the kernel today to see if I can find anything that could be the source of my woes.
Thanks in advance for any help you may offer.
Problems with event directory
Re: Problems with event directory
Search the WIKI for using add on drive.
You are talking about this: https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
I followed that, it does not work. Once I implement that, all existing recordings go away and new ones won't happen.
I think there's something else going on.
Here's the lines in the fstab that I used.
/mnt/raid6/zoneminder/events /usr/share/zoneminder/www/events none defaults,bind 0 2
/mnt/raid6/zoneminder/images /usr/share/zoneminder/www/images none defaults,bind 0 2
Please note: when gentoo installs zoneminder it puts symlinks from /usr/share/zoneminder/www/events (and images) to /var/lib/zoneminder/events (and images). I removed those sim links because I think they were an issue as well.
While not an expert in this area I remember seeing comments that you need to have permissions set to match your Apache user (www-data in Debian) in the destination directory. Have also seen that symbolic links may not work...
- knight-of-ni
Except that it does work if you follow the instructions correctly. Gentoo isn't doing anything different with symlinks compared to other distros.raydude wrote:You are talking about this: https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
You are not following the instructions stated in the link you referenced.raydude wrote:Here's the lines in the fstab that I used.
See the second item under Frequently Asked Questions which tells you not to map your drives under /usr/share/zoneminder.
And doing that can cause you to lose all your events after an upgrade. See the Frequently Asked Questions at the bottom of the wiki link you referenced.raydude wrote: Please note: when gentoo installs zoneminder it puts symlinks from /usr/share/zoneminder/www/events (and images) to /var/lib/zoneminder/events (and images). I removed those sim links because I think they were an issue as well.
What you need to do is find the real folders your events live under. Look under /var/lib or /var/cache. Put the original symlinks back (which point to those folders). Then recreate your mount points under fstab to point to those real folders.
If you take the time to read through and understand everything in that wiki link, then will you will find that this solution works perfectly.
Thanks for trying.
I know about ownership needing to be apache:apache.
It's not the upgrade that kills the videos. The videos do not get written when there is a symlink or I use the mounted folders. They simply do not write. There is no error message, just messages about the files disappearing and the data base entries being removed.
It's really weird. I get some recordings at first, but after a few minutes they are deleted because zoneminder can't find them.
Hopefully I'll get some time this weekend to play with it again. It's working with storage on the local drive at the moment.
