I updated a few days ago to 1.29 on Ubuntu 14.04, after some googling I was able to get everything working. Or at least I thought. I seem to be having some issue with getting the PTZ controls to work for my DCS-5020L's. When trying to go to a preset I get the below error.
Control reponse was status = undefined message = /usr/bin/zmcontrol.pl --preset=2 --command=presetGoto --id=1=>
When trying to move it using the arrows I get:
Control reponse was status = undefined message = /usr/bin/zmcontrol.pl --tiltstep=29 --command=moveRelup --id=1=>
Below is the control script I am using. The red are lines I have commented out/change based on this thread and I'm not sure they apply anymore. Any help would be greatly appreciated. Let me know if there is any additional information needed to troubleshoot this.
viewtopic.php?t=23244
# =========================================================================r
# ZoneMinder D-Link DCS-5020L IP Control Protocol Module, $Date: $, $Revision: $
# Copyright (C) 2013 Art Scheel
# This module contains the implementation of the D-Link DCS-5020L IP camera control
# protocol.
package ZoneMinder::Control::DCS5020L;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
#our $VERSION = $ZoneMinder::Base::VERSION;
# D-Link DCS-5020L Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
# $self->{ua}->agent( "ZoneMinder Control Agent/".ZM_VERSION );
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_Version);
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
my $req = HTTP::Request->new( POST=>"http://".$self->{Monitor}->{ControlAddress}."/PANTILTCONTROL.CGI" );
$req->content($cmd);
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub sendCmd2
my $self = shift;
my $cmd = shift;
my $result = undef;
my $req = HTTP::Request->new( GET=>"http://".$self->{Monitor}->{ControlAddress}."/$cmd".$self->{Monitor}->{ControlDevice} );
if ($res->is_success )
$result = !undef;
else
return( $result );
sub move
my $self = shift;
my $dir = shift;
my $panSteps = shift;
my $tiltSteps = shift;
my $cmd = "PanSingleMoveDegree=$panSteps&TiltSingleMoveDegree=$tiltSteps&PanTiltSingleMove=$dir";
$self->sendCmd( $cmd );
sub moveRelUpLeft
my $self = shift;
Debug( "Move Up Left" );
$self->move( 0, 1, 1 );
sub moveRelUp
my $self = shift;
Debug( "Move Up" );
$self->move( 1, 1, 1 );
sub moveRelUpRight
my $self = shift;
Debug( "Move Up" );
$self->move( 2, 1, 1 );
sub moveRelLeft
my $self = shift;
Debug( "Move Left" );
$self->move( 3, 1, 1 );
sub moveRelRight
my $self = shift;
Debug( "Move Right" );
$self->move( 5, 1, 1 );
sub moveRelDownLeft
my $self = shift;
Debug( "Move Down" );
$self->move( 6, 1, 1 );
sub moveRelDown
my $self = shift;
$self->move( 7, 1, 1 );
sub moveRelDownRight
my $self = shift;
$self->move( 8, 1, 1 );
# moves the camera to center on the point that the user clicked on in the video image.
# This isn't extremely accurate but good enough for most purposes
sub moveMap
# if the camera moves too much or too little, try increasing or decreasing this value
my $f = 11;
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
my $hor = $xcoord * 100 / $self->{Monitor}->{Width};
my $ver = $ycoord * 100 / $self->{Monitor}->{Height};
my $direction;
my $horSteps;
my $verSteps;
if ($hor < 50 && $ver < 50) {
# up left
$horSteps = (50 - $hor) / $f;
$verSteps = (50 - $ver) / $f;
$direction = 0;
} elsif ($hor >= 50 && $ver < 50) {
# up right
$horSteps = ($hor - 50) / $f;
$direction = 2;
} elsif ($hor < 50 && $ver >= 50) {
# down left
$verSteps = ($ver - 50) / $f;
$direction = 6;
} elsif ($hor >= 50 && $ver >= 50) {
# down right
$direction = 8;
my $v = int($verSteps + .5);
my $h = int($horSteps + .5);
Debug( "Move Map to $xcoord,$ycoord, hor=$h, ver=$v with direction $direction" );
$self->move( $direction, $h, $v );
# this clear function works, but should probably be disabled because
# it isn't possible to set presets yet.
sub presetClear
my $self = shift;
my $params = shift;
Debug( "Clear Preset $preset" );
my $cmd = "ClearPosition=$preset";
# not working yet
sub presetSet
my $self = shift;
my $params = shift;
# TODO need to first get current position $horPos and $verPos
#my $cmd = "PanTiltHorizontal=$horPos&PanTiltVertical=$verPos&SetName=$preset&SetPosition=$preset";
#$self->sendCmd( $cmd );
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "PanTiltPresetPositionMove=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "PanTiltSingleMove=4";
sub wake
my $self = shift;
Debug( "Wake - IR on" );
my $cmd = "setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=3&ConfigDayNightMode=Save";
$self->sendCmd2( $cmd );
sub sleep
my $self = shift;
Debug( "Sleep - IR off" );
my $cmd = "setDaynightMode?ReplySuccessPage=night.htm&ReplyErrorPage=errrnight.htm&DayNightMode=2&ConfigDayNightMode=Save";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for DCS-5020L
=head1 SYNOPSIS
use ZoneMinder::Database;
DLINK DCS-5020L
=head1 DESCRIPTION
ZoneMinder driver for the D-Link consumer camera DCS-5020L.
=head2 EXPORT
None by default.
=head1 SEE ALSO
See if there are better instructions for the DCS-5020L at
http://www.zoneminder.com/wiki/index.php/Dlink
=head1 AUTHOR
Art Scheel <lt>ascheel (at) gmail<gt>
=head1 COPYRIGHT AND LICENSE
LGPLv3
=cut
(Resolved)DCS-5020L PTZ Control Broken after Update
Re: DCS-5020L PTZ Control Broken after Update
I was able to figure this out. I was still getting errors for the same line. After comparing the original line, with the line from the forum link above I noticed there was a spelling mistake and also that the old line was caps where the new was lower case. After fixing these errors it now work.
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION);
