Problem with FLAT style
Basildane
Post by Basildane »
I really like the flat style but I have a problem with it. Every window opens up too small and displays scroll bars. And I have to stretch it to be able to see all the content. Zoneminder does this on every window. Example:
zoneminder screenshot.png (127.44 KiB) Viewed 3258 times
Re: Problem with FLAT style
I do not think your "problem" is related to the Flat style in Zoneminder. I did a test switch from Classic to Flat and back again and I saw no change in the events displayed list. it does seem that you have the fonts in your browser set large. If you are using Firefox try Zooming out to, say, 80% and see if that helps. If you are not using Firefox with Zoneminder I recommend you give it a try.
bb
Basildane
Post by Basildane »
Yes, it is Firefox. It is related to the font size. I would expect that CSS should not break depending on local settings on a user's machine, but that's cool. I can work around it.
It is also related to having the thumbnails on the right.
Basildane
Post by Basildane »
Btw, I changed the default font back to 16 in Firefox, hit ctrl-0, restarted FF, still have the same issue even with FF at defaults. If I shrink the font using ctrl-- twice, then it displays correctly, but I have to do that each time I open a window in Zoneminder.
Ah, I did not say to change the font but to change the zoom. And I had thumbnails on the right and did not have that issue.
bb
Basildane
Post by Basildane »
I did change the zoom. Have to do that every time I open a window.
