ARGH I"m SO CLOSE, take a look
yukaputz
Post by yukaputz »
Zoneminder 1.29 on ubuntu headless camera is a android ip cam.
Anyone ever seen something like this?
asker
Re: ARGH I"m SO CLOSE, take a look
Post by asker »
Yup I've seen this. Go to the Monitor Definition of this camera in ZM, click on source. Play with capture width/height/color space. Make sure they are accurate. Try different colorspace values.
Please read before posting:
ES docs
zmNinja docs
Is this an analog camera or local device?
That image could be the result of incorrectly selecting NTSC when it should be PAL or vice versa.
yukaputz
Post by yukaputz »
The device is a kyocera smart phone. The ip cam is android ip cam. width height and color space had no affect.
yukaputz
Post by yukaputz »
just for giggles I'm going to email the guy who wrote ip cam for android.
asker
Post by asker »
Do a search in these forums for IP webcam android --> in all cases (including your interleaved format) it was a problem of either WxH or colorspace or both. Make sure you try all combinations before you conclude it won't fix it
ES docs
zmNinja docs
yukaputz
Post by yukaputz »
Thanks guys. I gotta admit, I took a hard look at how much time I was spending on getting zoneminder to work. I finally gave up and went with ispy. For now it will do. I will come back to zone minder at some point I guess. For hodgepodging a bunch of different camera's together ispy is doing what I need for the moment.
