Please help - system down - empty events
Basildane
Post by Basildane »
No configuration has changed.
Today, most, BUT NOT ALL of my new recorded events are 0.
Duration 00:00:00 score 0.
I picked one at random and went to the events folder on the server, and the .jpg images are there.
But zoneminder says it's empty and won't play the event.
Basildane
Re: Please help - system down - empty events
Post by Basildane »
This is being logged continuously.
2016-03-11 11:54:28.107144	zma_m1		12673	WAR	Can't connect to frame server: Connection refused	zm_event.cpp	274
2016-03-11 11:54:28.003538	zma_m1		12673	ERR	Incomplete frame write: 219264 of 1113442 bytes written	zm_event.cpp	339
2016-03-11 11:54:27.818799	zma_m1		12673	WAR	Can't connect to frame server: Connection refused	zm_event.cpp	274
2016-03-11 11:54:27.675424	zma_m1		12673	WAR	Can't connect to frame server: Connection refused
Sorry if I sound like a broken record but I suspect there is something in your configuration that is not right. Not sure just where to point you other than to restate that the install procedures for ZM 1.29.0 do work on Ubuntu 14.04. I would recommend you try the Zoneminder on a stick and try to instal it on another hard drive then configure your cameras. You could also be running into MySQL issues if you have a large number of events. Mysqltuner will show you what you need to change.
bb
gblanco
Post by gblanco »
Full Disc ?
