Keep having to go in and hitting 'save' in the camera setup.
aarons6
Post by aarons6 »
my IP cameras keep going offline.. but they havent lost wifi connectivity.. all i have to do is go into the settings and hit save and they are back online.
this is new for this version as i havent had this problem in the past.. any settings or ideas?
Re: Keep having to go in and hitting 'save' in the camera setup.
More info please. What Source Type are you using, OS, Log messages if any, camera make/model, and etc.
bb
flyvert
Post by flyvert »
Two out of three of my cameras go 100% grey after some hours - hitting "Save" works, for a while...
viewtopic.php?f=34&t=24412
New to ZM, believe I save this in the "apt-get" version (1.26???) of zoneminder on Debian/Jessie and decided to build own from source - problem remain.
aarons6
Post by aarons6 »
ubuntu 14.10
IP cam, hootoo HT-IP212P. i have 3 of them.. 2 works flawless, 1 keeps stopping.. the error is cant connect. but when i log into the IP the camera is working.. if i go into the settings, and just hit save the camera comes back online.
my settings are
HTTP
SIMPLE
IP
/snapshot.cgi?user=admin&pwd=password
port 80.
640
480
rest is all default.
Looks like you may be out of RAM. Do a df and check tmpfs /run/shm
aarons6
Post by aarons6 »
none 2010708 135720 1874988 7% /run/shm
looks like a lot available?
