Page 1 of 1
Ubuntu 16.04
Posted: Sat Mar 26, 2016 8:23 pm
by bbunge
Ubuntu 16.04 is scheduled for release on April 21st. The final beta was released on March 25th and, I am pleased to announce, contains Zoneminder 1.29.0!
I have done a Zonemnder install on the final beta. The procedure is almost the same as ZM 1.29.0 on Ubuntu 15.10. I have found and documented that the php.ini in 16.04 is in a different location. There is a preliminary install procedure in the WIKI.
I have not worked on an update procedure...yet...
With this said, PLEASE, do not try to update a working Zoneminder/Ubuntu system that you can't afford to loose!!!
As Ubuntu 16.04 is still beta, do not expect everything to work right and do not expect to get help if you mess up your system.
