Foscam FI9803P V2 Camera working
Posted: Wed Mar 30, 2016 6:17 am
Fedora 23 machine, Zoneminder V1.29 installed
Camera is a Foscam FI9803P V2 1280/720 wireless access with Fixed IP address.
You need Windows Active-X add-on with Internet Explorer to config the camera.
The camera defaults to username = admin, and password is empty.
Monitor Setup TABS:
General Tab:
Name = [what ever you want to name your camera]
Server = None
Source Type = Ffmpeg
Function = [what ever you want, monitor is easiest to start with]
Enabled = checked
Leave all boxes having anything to do with FPS blank
Source Tab:
Source Path = rtsp://username:password@<camera IPaddr>:554/videoMain
Remote Method = RTP/RTSP
Options = blank
24 bit color
Capture Width = 1280
Capture Height = 720
All remaining Tabs are as defaulted during installation, I changed nothing.
Click the SAVE button to finish setup
Monitor Setup TABS:
General Tab:
Server = None
Enabled = checked
Source Tab:
Options = blank
24 bit color
