Monitor for online viewing
justbox
Post by justbox »
Hi!
How to set up so that if the user is not viewing the camera, the connection to the camera is broken, as in the Offer narrow channel constant link with the camera loads the network.
Привет !
Как настроить чтобы если пользователь не просматривает камеру , соединение с камерой разрывается , так как на обектах узкий канал постоянный линк с камерой нагружает сеть.
kevin186
Re: Monitor for online viewing
Post by kevin186 »
I am trying to guess here, but do you mean that you want zoneminder to stop reading the ip cam video feed if nobody is actively using the gui front end and viewing the live feed?
justbox
Post by justbox »
Yes, you need to see if the camera has not stopped the flow of browsing is transmitted
zoneminder we use for online viewing cameras only. We do not need a record.
undrwater
Post by undrwater »
This is a great idea for areas that have high activity normally and for which recording may not be necessary. I'm thinking specifically of pet areas as an example.
justbox
Post by justbox »
It is impossible to do with the camera session began only at the start of the Forum Views of the monitor?
