zmu command line tool
BiloxiGeek
Post by BiloxiGeek »
Poking around with zmu to pull some info on my monitors at the command line and while every command I run seems to work just fine I also get an additional line of output "Segementation fault".
Any ideas what might be causing this and how to fix?
[root@icezone ~]# zmu -f -m 201 -U user -P password
5.08
Segmentation fault
[root@icezone ~]#
I'm running SciLinux 7.1 (really should update to 7.2)
zoneminder-1.29.0-3.el7.centos from the repo
BiloxiGeek
Re: zmu command line tool SOLVED
Got the system updated to 7.2, rebooted and no longer getting segfaults on the zmu command line.
