Problem adding more then 8 cams
augustynr
Post by augustynr »
I have installed zoneminder using the Lubuntu image which went without any issues.
I have added first 8 ip cams without any issues but I am not able to add any more.
The cams are the same and if I change the ip on one of the first 8 to the 9th it works ....
I see only zmc running for firs 8 cams.
I have 3Gig of ram on that box.
Any idea what is going on?
How would I go about resolving it.
Re: Problem adding more then 8 cams
You are out of memory. Lower the resolution of the cameras, add more memory.
Glad you tried my Lubuntu install!!!
bb
augustynr
Post by augustynr »
Thanks,
That worked :)
btw: the Lubuntu installation worked well, I have disabled the gui to save the memory.
I am using it in XenServer without any problems.
