Zoom function on PelcoP.pm
Posted: Fri Apr 01, 2016 11:49 pm
Hi
I'm using Zoneminder 1.29.0 on Ubuntu 15.10 64 bit. I have a American Dynamics PTZ camera hooked up using RS-422 PelcoP. I have all fuctions working besides zoom tele.
Heres how my PelcoP.pm file looks like:
Has anyone got this to work.
try's sending the command but nothing happens! Any idea?????
# ZoneMinder Pelco-P Control Protocol Module, $Date$, $Revision$
# This module contains the implementation of the Pelco-P camera control
# protocol
package ZoneMinder::Control::PelcoP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Pelco-P Control Protocol
use Time::HiRes qw( usleep );
use constant STX => 0xa0;
use constant ETX => 0xaf;
use constant COMMAND_GAP => 100000; # In ms
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use Device::SerialPort;
$self->{port} = new Device::SerialPort( $self->{Monitor}->{ControlDevice} );
$self->{port}->baudrate(4800);
$self->{port}->databits(8);
$self->{port}->parity('none');
$self->{port}->stopbits(1);
$self->{port}->handshake('none');
$self->{port}->read_const_time(50);
$self->{port}->read_char_time(10);
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
$self->{port}->close();
sub printMsg
if ( logDebugging() )
my $self = shift;
my $msg = shift;
my $prefix = shift || "";
$prefix = $prefix.": " if ( $prefix );
my $line_length = 16;
my $msg_len = int(@$msg);
my $msg_str = $prefix;
for ( my $i = 0; $i < $msg_len; $i++ )
if ( ($i > 0) && ($i%$line_length == 0) && ($i != ($msg_len-1)) )
$msg_str .= sprintf( "\n%*s", length($prefix), "" );
$msg_str .= sprintf( "%02x ", $msg->[$i] );
$msg_str .= "[".$msg_len."]";
Debug( $msg_str );
sub sendCmd
my $self = shift;
my $cmd = shift;
my $ack = shift || 0;
my $result = undef;
# Pelco P protocol checksum is created by XOR'ing the first seven bytes in the message
# including the first byte, the STX sync packet
my $checksum = 0x00;
for ( my $i = 0; $i < int(@$cmd); $i++ )
$checksum ^= $cmd->[$i];
$checksum &= 0xff;
push( @$cmd, $checksum );
$self->printMsg( $cmd, "Tx" );
my $id = $cmd->[0] & 0xf;
my $tx_msg = pack( "C*", @$cmd );
#print( "Tx: ".length( $tx_msg )." bytes\n" );
my $n_bytes = $self->{port}->write( $tx_msg );
if ( !$n_bytes )
Error( "Write failed: $!" );
if ( $n_bytes != length($tx_msg) )
Error( "Incomplete write, only ".$n_bytes." of ".length($tx_msg)." written: $!" );
if ( $ack )
Debug( "Waiting for ack" );
my $max_wait = 3;
my $now = time();
while( 1 )
my ( $count, $rx_msg ) = $self->{port}->read(4);
if ( $count )
#print( "Rx1: ".$count." bytes\n" );
my @resp = unpack( "C*", $rx_msg );
printMsg( \@resp, "Rx" );
if ( $resp[0] = 0x80 + ($id<<4) )
if ( ($resp[1] & 0xf0) == 0x40 )
my $socket = $resp[1] & 0x0f;
Debug( "Got ack for socket $socket" );
$result = !undef;
else
Error( "Got bogus response" );
last;
else
Error( "Got message for camera ".(($resp[0]-0x80)>>4) );
if ( (time() - $now) > $max_wait )
Warning( "Response timeout" );
last;
sub remoteReset
my $self = shift;
Debug( "Remote Reset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0f, 0x00, 0x00, ETX );
$self->sendCmd( \@msg );
sub resetDefaults
my $self = shift;
Debug( "Reset Defaults" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x29, 0x00, 0x00, ETX );
sub cameraOff
my $self = shift;
Debug( "Camera Off" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x08, 0x00, 0x00, 0x00, ETX );
sub cameraOn
my $self = shift;
Debug( "Camera On" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x88, 0x00, 0x00, 0x00, ETX );
sub autoScan
my $self = shift;
Debug( "Auto Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x90, 0x00, 0x00, 0x00, ETX );
sub manScan
my $self = shift;
Debug( "Manual Scan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x10, 0x00, 0x00, 0x00, ETX );
sub stop
my $self = shift;
Debug( "Stop" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x00, 0x00, 0x00, ETX );
sub moveConUp
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'tiltspeed' );
my $autostop = $self->getParam( $params, 'autostop', 0 );
Debug( "Move Up" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x08, 0x00, $speed, ETX );
if( $autostop && $self->{Monitor}->{AutoStopTimeout} )
usleep( $self->{Monitor}->{AutoStopTimeout} );
$self->stop( $params );
sub moveConDown
my $self = shift;
my $params = shift;
Debug( "Move Down" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x10, 0x00, $speed, ETX );
$self->stop();
sub moveConLeft
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'panspeed' );
Debug( "Move Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x04, $speed, 0x00, ETX );
$self->stop();
sub moveConRight
my $self = shift;
my $params = shift;
Debug( "Move Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x02, $speed, 0x00, ETX );
$self->stop();
sub moveConUpLeft
my $self = shift;
my $params = shift;
my $panspeed = $self->getParam( $params, 'panspeed', 0x3f );
my $tiltspeed = $self->getParam( $params, 'tiltspeed', 0x3f );
Debug( "Move Up/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0c, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x0a, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownLeft
my $self = shift;
my $params = shift;
Debug( "Move Down/Left" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x14, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveConDownRight
my $self = shift;
my $params = shift;
Debug( "Move Down/Right" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x12, $panspeed, $tiltspeed, ETX );
$self->stop();
sub moveStop
my $self = shift;
Debug( "Move Stop" );
$self->stop();
sub flip180
my $self = shift;
Debug( "Flip 180" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x21, ETX );
sub zeroPan
my $self = shift;
Debug( "Zero Pan" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, 0x22, ETX );
sub _setZoomSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Zoom Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x25, 0x00, $speed, ETX );
sub zoomStop
my $self = shift;
Debug( "Zoom Stop" );
$self->stop();
$self->_setZoomSpeed( 0 );
sub zoomConTele
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x01 );
Debug( "Zoom Tele" );
$self->_setZoomSpeed( $speed );
usleep( COMMAND_GAP );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x20, 0x00, 0x00, ETX );
$self->zoomStop();
sub zoomConWide
my $self = shift;
my $params = shift;
Debug( "Zoom Wide" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x40, 0x00, 0x00, ETX );
$self->zoomStop();
sub _setFocusSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Focus Speed $speed" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x27, 0x00, $speed, ETX );
sub focusConNear
my $self = shift;
my $params = shift;
my $speed = $self->getParam( $params, 'speed', 0x03 );
Debug( "Focus Near" );
$self->_setFocusSpeed( $speed );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x01, 0x00, 0x00, 0x00, ETX );
$self->_setFocusSpeed( 0 );
sub focusConFar
my $self = shift;
my $params = shift;
Debug( "Focus Far" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x80, 0x00, 0x00, ETX );
sub focusStop
my $self = shift;
Debug( "Focus Stop" );
$self->stop();
sub focusAuto
my $self = shift;
Debug( "Focus Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x00, ETX );
sub focusMan
my $self = shift;
Debug( "Focus Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2b, 0x00, 0x02, ETX );
sub _setIrisSpeed
my $self = shift;
my $speed = shift;
Debug( "Set Iris Speed $speed" );
sub irisConClose
my $self = shift;
my $params = shift;
Debug( "Iris Close" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x04, 0x00, 0x00, 0x00, ETX );
$self->_setIrisSpeed( 0 );
sub irisConOpen
my $self = shift;
my $params = shift;
Debug( "Iris Open" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x02, 0x80, 0x00, 0x00, ETX );
sub irisStop
my $self = shift;
Debug( "Iris Stop" );
$self->stop();
sub irisAuto
my $self = shift;
Debug( "Iris Auto" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x00, ETX );
sub irisMan
my $self = shift;
Debug( "Iris Man" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x2d, 0x00, 0x02, ETX );
sub writeScreen
my $self = shift;
my $params = shift;
my $string = $self->getParam( $params, 'string' );
Debug( "Writing '$string' to screen" );
my @chars = unpack( "C*", $string );
for ( my $i = 0; $i < length($string); $i++ )
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x15, $i, $chars[$i], ETX );
sub clearScreen
my $self = shift;
Debug( "Clear Screen" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x17, 0x00, 0x00, ETX );
sub clearPreset
my $self = shift;
my $params = shift;
my $preset = $self->getParam( $params, 'preset', 1 );
Debug( "Clear Preset $preset" );
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x05, 0x00, $preset, ETX );
sub presetSet
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x03, 0x00, $preset, ETX );
sub presetGoto
my $self = shift;
my $params = shift;
my @msg = ( STX, $self->{Monitor}->{ControlAddress}, 0x00, 0x07, 0x00, $preset, ETX );
sub presetHome
my $self = shift;
Debug( "Home Preset" );
sub reset
my $self = shift;
Debug( "Reset" );
$self->remoteReset();
$self->resetDefaults();
sub wake
my $self = shift;
Debug( "Wake" );
$self->cameraOn();
sub sleep
my $self = shift;
Debug( "Sleep" );
$self->cameraOff();
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
use ZoneMinder::Database;
blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
2016-04-02 00:48:38.775330 zmcontrol 15075 DBG Tx: a0 00 00 25 00 00 af 2a [8] zmcontrol.pl
2016-04-02 00:48:38.672990 zmcontrol 15075 DBG Set Zoom Speed 0 zmcontrol.pl
2016-04-02 00:48:38.550220 zmcontrol 15075 DBG Tx: a0 00 00 00 00 00 af 0f [8] zmcontrol.pl
2016-04-02 00:48:38.454920 zmcontrol 15075 DBG Stop zmcontrol.pl
2016-04-02 00:48:38.376160 zmcontrol 15075 DBG Zoom Stop zmcontrol.pl
2016-04-02 00:48:38.136730 zmcontrol 15075 DBG Tx: a0 00 00 20 00 00 af 2f [8] zmcontrol.pl
2016-04-02 00:48:37.941430 zmcontrol 15075 DBG Tx: a0 00 00 25 00 18 af 32 [8] zmcontrol.pl
2016-04-02 00:48:37.850930 zmcontrol 15075 DBG Set Zoom Speed 24 zmcontrol.pl
2016-04-02 00:48:37.771700 zmcontrol 15075 DBG Zoom Tele zmcontrol.pl
2016-04-02 00:48:37.712790 zmcontrol 15075 DBG Tx: a0 00 00 25 00 00 af 2a [8] zmcontrol.pl
2016-04-02 00:48:37.623740 zmcontrol 15075 DBG Set Zoom Speed 0 zmcontrol.pl
2016-04-02 00:48:37.534170 zmcontrol 15075 DBG Tx: a0 00 00 00 00 00 af 0f [8] zmcontrol.pl
2016-04-02 00:48:37.443470 zmcontrol 15075 DBG Stop zmcontrol.pl
2016-04-02 00:48:37.365280 zmcontrol 15075 DBG Zoom Stop zmcontrol.pl
2016-04-02 00:48:37.134070 zmcontrol 15075 DBG Tx: a0 00 00 20 00 00 af 2f [8] zmcontrol.pl
2016-04-02 00:48:36.942440 zmcontrol 15075 DBG Tx: a0 00 00 25 00 18 af 32 [8] zmcontrol.pl
2016-04-02 00:48:36.853520 zmcontrol 15075 DBG Set Zoom Speed 24 zmcontrol.pl
2016-04-02 00:48:36.620400 zmcontrol 15075 DBG Zoom Tele zmcontrol.pl
