I had zoneminder running on Ubuntu 14.08. I had done an update on Ubuntu and the zoneminder would not run anymore. I have reinstalled several times and getting nowhere. The error I am getting on the term. is on the attached screen shot. what is wrong?
Ray
Zoneminder failure
Re: Zoneminder failure
It doesn't look like you have followed installation instructions.
https://wiki.zoneminder.com/Ubuntu
For example the upgrade instructions here talk about many things including changing permissions to the file you listed in your screenshot
https://wiki.zoneminder.com/Common_Issu ... r_from_PPA
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Could you try to run the command "sudo service zoneminder start"?n1kxj wrote:I had zoneminder running on Ubuntu 14.08. I had done an update on Ubuntu and the zoneminder would not run anymore. I have reinstalled several times and getting nowhere. The error I am getting on the term. is on the attached screen shot. what is wrong?
Ray
your example of the error is a result of a permission problem with the /etc/zm/zm.conf
you could try these methods which are detailed in the instructions mentioned above in this thread.
the next error you would encounter is fixed by changing the permissions of /var/cache/zoneminder so then type:
root#chown www-data /etc/zm/zm.conf
root#chown -R www-data /var/cache/zoneminder
