In the ZM database I see a column in the Monitors table named "signal_check_colour" that is used to detect when a monitor has lost signal. I am unable to find where to set this option in the UI. What am I missing? Is there a UI for this or is it just set to the default value defined in the database?
Ken
Where to Set "Signal_Check_Colour"??
Re: Where to Set "Signal_Check_Colour"??
I reviewed the monitor.php code and now see that the SignalCheckColour only appears on the Monitor configuration page if the monitor is defined as LOCAL. My monitors are defined as REMOTE and IP 127.0.0.1 but I am still getting SIGNAL events on one monitor in particular. When I review the image causing the SIGNAL event it is clearly a bogus event. The SignalCheckColour is set to #0000c0 and since my blue truck is in the scene I suspect it tripping off my truck.
It seems impossible to change the SignalCheckColour for a REMOTE monitor and ZM is still doing Signal checks on remotes. Should it be checking signal on remotes? I guess I'll dig into that code next.
