ERR: Received unexpected SDES item type 2
Posted: Mon Apr 04, 2016 7:14 am
i've used zm for a few years now, for a small home installation with 4 samsung ip cameras, accessed by ffmpeg via a rtsp stream, 3 cameras in mocord mode, 1 in record.
Everything was - and is - working fine, until now, when i started playing with REMOTE input type in the attempt to save cpu on my old atom 330, 2gb ram.
Actually, cameras do work, and i can see the images, but i'm getting too many (100's in few min) of this errors Received unexpected SDES item type 2 filling the logs.
It is almost certainly something related to rtp stream, but i cant debug it any further.
Any suggestion, please?
Thank you
Thank you
2016-04-04 01:41:36.517787 zmc_m5 1227 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:36.227546 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:35.227682 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:35.142429 zmc_m3 1210 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:35.034550 zmwatch 1267 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-04-04 01:41:34.961120 zmwatch 1267 INF Watchdog starting zmwatch.pl
2016-04-04 01:41:34.572527 zma_m3 1263 INF In mode 5/1, warming up zma.cpp 142
2016-04-04 01:41:34.271350 undef 1263 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:34.235076 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:34.192320 zmdc 1127 INF 'zmwatch.pl' starting at 16/04/04 01:41:34, pid = 1267 zmdc.pl
2016-04-04 01:41:34.192260 zmdc 1267 INF 'zmwatch.pl' started at 16/04/04 01:41:34 zmdc.pl
2016-04-04 01:41:34.092240 zmdc 1263 INF 'zma -m 3' started at 16/04/04 01:41:34 zmdc.pl
2016-04-04 01:41:34.091810 zmdc 1127 INF 'zma -m 3' starting at 16/04/04 01:41:34, pid = 1263 zmdc.pl
2016-04-04 01:41:34.020050 zmfilter 1239 INF Scanning for events zmfilter.pl
2016-04-04 01:41:34.017150 zmdc 1127 INF Starting pending process, zma -m 3 zmdc.pl
2016-04-04 01:41:33.515689 zmc_m2 1195 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:33.307863 zma_m1 1250 INF In mode 5/1, warming up zma.cpp 142
2016-04-04 01:41:33.223674 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:32.949424 zma_m2 1248 INF In mode 4/1, warming up zma.cpp 142
2016-04-04 01:41:32.865203 undef 1250 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:32.788610 zmdc 1252 INF 'zmaudit.pl -c' started at 16/04/04 01:41:32 zmdc.pl
2016-04-04 01:41:32.787980 zmdc 1127 INF 'zmaudit.pl -c' starting at 16/04/04 01:41:32, pid = 1252 zmdc.pl
2016-04-04 01:41:32.563960 zmdc 1250 INF 'zma -m 1' started at 16/04/04 01:41:32 zmdc.pl
2016-04-04 01:41:32.563570 zmdc 1127 INF 'zma -m 1' starting at 16/04/04 01:41:32, pid = 1250 zmdc.pl
2016-04-04 01:41:32.533999 undef 1248 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:32.510998 zma_m5 1236 INF In mode 5/1, warming up zma.cpp 142
2016-04-04 01:41:32.474070 zmdc 1127 INF Starting pending process, zma -m 1 zmdc.pl
2016-04-04 01:41:32.331210 zmdc 1248 INF 'zma -m 2' started at 16/04/04 01:41:32 zmdc.pl
2016-04-04 01:41:32.331200 zmdc 1127 INF 'zma -m 2' starting at 16/04/04 01:41:32, pid = 1248 zmdc.pl
2016-04-04 01:41:32.208125 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:32.101360 zmdc 1127 INF Starting pending process, zma -m 2 zmdc.pl
2016-04-04 01:41:31.544061 zmc_m5 1227 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:31.425816 zmc_m5 1227 INF Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.1.151:554/profile2/media.smp' zm_rtsp.cpp 398
2016-04-04 01:41:31.420140 zmdc 1239 INF 'zmfilter.pl' started at 16/04/04 01:41:31 zmdc.pl
2016-04-04 01:41:31.419940 zmdc 1127 INF 'zmfilter.pl' starting at 16/04/04 01:41:31, pid = 1239 zmdc.pl
2016-04-04 01:41:31.387062 zma_m5 1236 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-04-04 01:41:31.224096 undef 1236 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:31.207357 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:31.169467 zmc_m5 1225 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-04-04 01:41:31.052100 zmdc 1236 INF 'zma -m 5' started at 16/04/04 01:41:31 zmdc.pl
2016-04-04 01:41:31.042950 zmdc 1127 INF 'zma -m 5' starting at 16/04/04 01:41:31, pid = 1236 zmdc.pl
2016-04-04 01:41:30.985590 zmdc 1127 INF Starting pending process, zma -m 5 zmdc.pl
2016-04-04 01:41:30.933790 zmdc 1127 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2016-04-04 01:41:30.873433 zma_m5 1229 ERR Shared data not initialised by capture daemon for monitor corte zm_monitor.cpp 442
2016-04-04 01:41:30.819868 undef 1229 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:30.612310 zmdc 1229 INF 'zma -m 5' started at 16/04/04 01:41:30 zmdc.pl
2016-04-04 01:41:30.609840 zmdc 1127 INF 'zma -m 5' starting at 16/04/04 01:41:30, pid = 1229 zmdc.pl
2016-04-04 01:41:30.358077 undef 1225 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-04-04 01:41:30.214173 zmc_m1 1187 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:30.186590 zmdc 1225 INF 'zmc -m 5' started at 16/04/04 01:41:30 zmdc.pl
2016-04-04 01:41:30.183810 zmdc 1127 INF 'zmc -m 5' starting at 16/04/04 01:41:30, pid = 1225 zmdc.pl
2016-04-04 01:41:30.172015 zmc_m3 1210 ERR Received unexpected SDES item type 2, ignoring zm_rtp_ctrl.cpp 127
2016-04-04 01:41:30.076660 zmdc 1127 INF Starting pending process, zmc -m 5
