Page 1 of 1
USB Webcam not running in ZM but does work in Cheese. What to do?
Posted: Wed Apr 06, 2016 4:31 pm
by 777funk
Cuirous how I can get this working. It does work in Cheese. The camera is showing in Red on the location at the ZM homepage. It shows to be here in the terminal search:
/dev/video0
Re: USB Webcam not running in ZM but does work in Cheese. What to do?
Posted: Wed Apr 06, 2016 9:01 pm
by bbunge
Did you:
adduser www-data video
I also have the best luck with using PAL-B for USB cams. Get the resolution right... try 320x240 to begin with.
Posted: Thu Apr 07, 2016 12:47 am
by 777funk
Yes I tried that (on my regular Ubuntu terminal and no go). I hadn't tried PAL-B but did just try it and the USB cam is still showing RED in the source.
Posted: Thu Apr 07, 2016 12:53 am
by bbunge
What errors are you getting in your log?
Posted: Thu Apr 07, 2016 2:24 am
by 777funk
Sure, here are the errors pertaining to the webcam.
2016-04-06 21:15:00.199190 zmdc 4163 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2016-04-06 21:15:00.172443 zmc_dvideo0 15961 ERR No monitors found zmc.cpp
Posted: Fri Apr 08, 2016 3:46 am
by 777funk
Got it.
It either had to do with needing this:
sudo chmod 666 /dev/video0
or maybe this:
zmu -q -d /dev/video0 -U <zoneminder username here> -P <zoneminder password here>
or maybe (but probably not) this:
ServerName localhost
in apache2.conf in /etc/apache2 and restart apache the notice will disappear.
after I'd already done this:
sudo adduser www-data video
sudo a2enmod cgi
which didn't work until I did the above.
then the settings:
Capture Method: Video for Linux 2
Device Channel: 0
Pal B
Auto
24 bit
640x480
Posted: Fri Apr 08, 2016 11:04 am
by SteveGilvarry
So 'adduser www-data video', which added apache user to video group, but then actually making sure that group has access. If you knew the permissions on on /dev/video0 before 666 then we could confirm that. Mainly just make sure that group is video and it has rw access. So you could pare back chmod 666.
