Cant get HD working
akiaki
Cant get HD working
Post by akiaki »
Hi guys, I have installed Zoneminder via Docker on my Xpenology server.
I was pulling my hair why wont my cheap Jooan A5 camera work, but I finally got it to work by adjusting capture width and height to: 720x540
When viewing rtsp stream in VLC i get 720p resolution. When using their app on android, I also get HD resolution.
As soon as I put 1280x720 resolution in ZM i get broken picture icon.
My current setup is using libvlc as ffmepg is not working for me for some reason.
Does anyone have some ideas I can try maybe? I am using ZM for the first time now, but would like to get full resolution available as current picture quality is not so good compared to VLC or APP.
Thanks in advance!
Re: Cant get HD working
Last info I have is that Docker installs 1.28.1 which did not support libvlc fully.
