Applying State Change Please Wait
Posted: Sun Apr 10, 2016 5:05 pm
I've installed 1.26.5 on a Raspberry Pi running Raspbian. 1.26.5 is what's included in their repo.
I followed the wiki guide (which is for Ubuntu) and with the exception of adding the iconner repo, I followed the instructions to the letter.
But the state never changes to from Stopped in the control panel. There are no logs in /var/log/zm either.
If instead of cliccking "Stopped" I click "version", I get this: "Version mismatch, system is version 1.26.5, database is ZM_DYN_DB_VERSION.
Please run zmupdate.pl to update"
zmupdate.pl fails with errors:
Bareword "ZM_PATH_LOGS" not allowed while "strickt subs" in use at /usr/share/perl5/ZoneMinder/Logger.pm line 153
BEGIN not safe after errors--complation aborted... Logger.pm line 168
Compilation failde in require at /usr/bin/zmupdate.pl line 48
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 48
It's a mess.. is there an 'easy way' guide that works on the raspberry pi?
Edit: also tried this raspberry pi specific tutorial but no improvement: http://www.holylinux.net/content/raspbe ... zoneminder
