Hello
Someone already exprienced these two ?
Milesight MS-C2182-P
and
Milesight MS-C2163-PNA
[Resolved]Milesight MS-C2182-P and MS-C2163-PNA
Re: Milesight MS-C2182-P and MS-C2163-PNA
Ok folks,
I get all of them work by myself and I want to share it with you.
I follow some step here : https://wiki.zoneminder.com/Dahua
Now the parameters i simply enter :
Source type - FFMPEG
Source Path - rtsp://admin:admin@yourzmserverip
Capture Width 1280
Capture High 720
Et voila.
Ps : This should be in MAIN rule in compatibility check!
That works for both of them.Before I try to get a camera to work on Zoneminder, I try to look at it using the Swiss Army Knife of video tools, the VLC Player. Just download the player and put the following url into the File/Open Network dialog box:
rtsp://admin:admin@yourzmserverip (eg. 192.168.10.86)
You should see pictures coming out of your camera. If you don't, then I am not going to be able to help you much. The camera does respond to pings, so you might try pinging it. If you can't ping it, you are not going to get very far.
Capture Width 1280
Capture High 720
Et voila.
