Page 1 of 1
[Resolved]Milesight MS-C2182-P and MS-C2163-PNA
Posted: Wed Apr 20, 2016 10:50 am
by caseyj
Hello
Someone already exprienced these two ?
and
Milesight MS-C2163-PNA
Re: Milesight MS-C2182-P and MS-C2163-PNA
Posted: Fri Apr 29, 2016 5:24 am
by caseyj
Ok folks,
I get all of them work by myself and I want to share it with you.
I follow some step here : https://wiki.zoneminder.com/Dahua
Before I try to get a camera to work on Zoneminder, I try to look at it using the Swiss Army Knife of video tools, the VLC Player. Just download the player and put the following url into the File/Open Network dialog box:
rtsp://admin:admin@yourzmserverip (eg. 192.168.10.86)
You should see pictures coming out of your camera. If you don't, then I am not going to be able to help you much. The camera does respond to pings, so you might try pinging it. If you can't ping it, you are not going to get very far.
That works for both of them.
Now the parameters i simply enter :
Source type - FFMPEG
Source Path - rtsp://admin:admin@yourzmserverip
Capture Width 1280
Capture High 720
Et voila.
Ps : This should be in MAIN rule in compatibility check!
