system log not reporting (mysql error)
iitywygms
Post by iitywygms »
Distributor ID: Ubuntu
Description: Ubuntu 14.04.4 LTS
Release: 14.04
mysql Ver 14.14 Distrib 5.5.49, for debian-linux-gnu (x86_64) using readline 6.3
Zoneminder v1.29.0. Everything is operating as it should except the log.
When I go to check the logs I get the following error.
2016-04-25 20:38:55.197010 zmfilter 12993 FAT Can't execute 'SELECT * FROM Filters WHERE Background = 1 and( AutoArchive = 1 or AutoVideo = 1 or AutoUpload = 1 or AutoEmail = 1 or AutoMessage = 1 or AutoExecute = 1 zmfilter.pl
2016-04-25 20:37:34.508480 zmwatch 13006 FAT Can't execute: MySQL server has gone away zmwatch.pl
2016-04-22 11:45:10.092120 zmaudit 2383 FAT Can't execute: MySQL server has gone away zmaudit.pl
Ideas?
iitywygms
Re: system log not reporting (mysql error)
Post by iitywygms »
Can I offer more information?
I want to add a few cameras and will be needing the ability to check logs while adding them.
iitywygms
Post by iitywygms »
Anyone? Bueller, Bueller.
SteveGilvarry
Post by SteveGilvarry »
No idea obviously something with mysql connection as opposed to ZM itself. Can you add a monitor OK when this error is occurring? Is it a new build so never worked or just stopped at some point?
I am sure you can google it, but some things to tweak here.
http://stackoverflow.com/questions/1242 ... e-sql-file
iitywygms
Post by iitywygms »
Well I tried some of the suggestions linked above. Nothing helped.
This has been a running system for a few years now.
I can add monitors, change filters, and everything else. Its just I dont get any logs reported. Just the database has gone away message.
I have several months of mysql backups. Guess I could try one from a month ago or so.?
Its just that this server also have mythtv backend running, and I need to be careful when fn with the database. Everything seems to work fine, just now information in the error logs?????
Where else should I look for errors??
iitywygms
Post by iitywygms »
Can zoneminder run if it does not have a database? (database has gone away message)
Because zoneminder is running just fine. Everything.
If you are running other databases you could be running out of resources with MySQL. Use mysqltuner to see if you need to adjust a setting in my.cnf.
bb
iitywygms
Post by iitywygms »
Still same error.
2016-05-02 18:54:51.040420 zmwatch 2402 FAT Can't execute: MySQL server has gone away zmwatch.pl
2016-05-02 18:43:09.637390 zmaudit 3232 FAT Can't execute: MySQL server has gone away zmaudit.pl
Notes.
I ran this.
mysqlcheck -uroot -p --optimize --databases zm
Gor a bunch of this. All checked okay.
zm.Config
note : Table does not support optimize, doing recreate + analyze instead
status : OK
zm.ControlPresets
status : OK
I ran this.
sudo mysqltuner
Got this.
-------- Storage Engine Statistics -------------------------------------------
[--] Status: +Archive -BDB -Federated +InnoDB -ISAM -NDBCluster
[--] Data in PERFORMANCE_SCHEMA tables: 0B (Tables: 17)
[--] Data in MyISAM tables: 93M (Tables: 106)
[--] Data in InnoDB tables: 109M (Tables: 556)
[!!] Total fragmented tables: 42
-------- Security Recommendations -------------------------------------------
[!!] User '@kapok' has no password set.
[!!] User '@localhost' has no password set.
-------- Performance Metrics -------------------------------------------------
[--] Up for: 3m 35s (1K q [7.149 qps], 397 conn, TX: 7M, RX: 264K)
[--] Reads / Writes: 61% / 39%
[--] Total buffers: 280.0M global + 48.8M per thread (151 max threads)
[OK] Maximum possible memory usage: 7.5G (48% of installed RAM)
[OK] Slow queries: 2% (44/1K)
[OK] Highest usage of available connections: 35% (54/151)
[OK] Key buffer size / total MyISAM indexes: 64.0M/94.0M
[OK] Key buffer hit rate: 99.5% (7K cached / 43 reads)
[OK] Query cache efficiency: 32.9% (252 cached / 767 selects)
[OK] Query cache prunes per day: 0
[OK] Sorts requiring temporary tables: 0% (0 temp sorts / 46 sorts)
[!!] Temporary tables created on disk: 35% (204 on disk / 581 total)
[OK] Thread cache hit rate: 85% (57 created / 397 connections)
[OK] Table cache hit rate: 25% (256 open / 998 opened)
[OK] Open file limit used: 25% (262/1K)
[OK] Table locks acquired immediately: 100% (742 immediate / 742 locks)
[OK] InnoDB data size / buffer pool: 109.2M/128.0M
-------- Recommendations -----------------------------------------------------
General recommendations:
Run OPTIMIZE TABLE to defragment tables for better performance
MySQL started within last 24 hours - recommendations may be inaccurate
When making adjustments, make tmp_table_size/max_heap_table_size equal
Reduce your SELECT DISTINCT queries without LIMIT clauses
Variables to adjust:
tmp_table_size (> 32M)
max_heap_table_size (> 1G)
iitywygms
Post by iitywygms »
I dunno.
Today I was poking around and decided to stop and start zoneminder from the webpage instead of using the command line.
After that the log reporting is fine.
I had restarted the entire computer several times, along with several restarts of both mysql and zoneminder from command lines.
So I dunno????
But its all good now :?: :?: :?: :?: :?:
You need to adjust settings in my.cnf. See recommendations from your output:
Make sure you have the RAM to cover the 1G setting...
iitywygms
Post by iitywygms »
It has been setup like recommended.
I dont know why mysqltuner is telling me to change things.
Here is my.cnf
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/serve ... ables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
# Kevin edited next 2 lines
innodb_file_per_table
wait_timeout=600
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 0.0.0.0
# * Fine Tuning
key_buffer = 48M
max_allowed_packet = 128M
thread_stack = 192K
thread_cache_size = 4
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
table_cache = 4096
#thread_concurrency = 10
#I added
tmp_table_size = 512M
max_heap_table_size = 1024M
sort_buffer_size = 48M
net_buffer_length = 1M
query_cache_type = 1
query_cache_size = 4M
join_buffer_size = 256K
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
# other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
max_allowed_packet = 16M
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
# * IMPORTANT: Additional settings that can override those from this file!
# The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
