Since the update to 1.29.0 (made it following the instructions here) I have an issue with some cameras. The cameras are some cheap Chinese "wanscam" branded ones. Well, everything works great but these cameras sometimes reboots for no reason (or due to power downs). And it was no issue for ZM to reconnect after those reboots before 1.29.0 update. But now it doesn't. The camera will not be recorded and I can't see the feed via ZM (I still can see a feed via camera's web interface, but not trough the link I have in ZM for the camera as the source - /videostream.cgi?user=blablabla one). Restarting ZM using "/etc/init.d/zoneminder restart" helps though. As a temporary solution I'm restarting zoneminder every hour via cron, but it's an ugly one
Here is a piece of log, showing only ERR level and at the time camera 1 has been rebooted (latest events are at the beginning):
2016-05-07 16:55:21.144139 web_php 11175 ERR Timed out waiting for msg /var/run/zm/zms-852562s.sock /usr/share/zoneminder/www/includes/functions.php 2371
2016-05-07 16:55:18.537025 zms 3815 ERR Terminating, last frame sent time 1462629318.036930 secs more than maximum of 10.000000 zm_monitor.cpp 4392
2016-05-07 16:53:54.394235 web_php 32113 ERR socket_sendto( /var/run/zm/zms-035508s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-05-07 16:53:51.251791 web_php 32113 ERR socket_sendto( /var/run/zm/zms-035508s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-05-07 16:53:48.217189 web_php 32113 ERR socket_sendto( /var/run/zm/zms-035508s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-05-07 16:53:45.406720 zms 3632 ERR Terminating, last frame sent time 1462629224.906620 secs more than maximum of 10.000000 zm_monitor.cpp 4392
2016-05-07 16:47:45.213594 zmc_m1 2924 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-05-07 16:47:45.189669 zmc_m1 2924 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-05-07 16:47:45.164289 zmc_m1 2924 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
Here are some system details:
OS: Ubuntu 14.04.4 LTS (up to date)
zoneminder package installed via iconnor PPA
uname -a: Linux cams 3.13.0-85-generic #129-Ubuntu SMP Thu Mar 17 20:50:15 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I found similar post dated year 2014, but there is no solution. Can someone help somehow?
