Camera Bluestork BS-CAM-OR/HD
Philippe48
Post by Philippe48 »
Is the camera Bluestork BS-CAM-OR/HD compatible with Zoneminder ?
tuxmos
Re: Camera Bluestork BS-CAM-OR/HD
Post by tuxmos »
Test these URL's with VLC and you know it.
https://www.ispyconnect.com/man.aspx?n=BlueStork
If the correct URL is not present, the camera may also compatible with others. It is also worth other URL's, especially rtsp try. Since manufacturers in China often take the same software as the basis for their own firmware, the variety is not too big.
e.g. rtsp://CAM-IP:554/11 or rtsp://CAM-IP:554/mpeg4 or rtsp://CAM-IP:554/user=username&password=password&channel=1&stream=0.sdp real_stream are the most common.
