FAILED SU (to Server) apache on none
goddi
Post by goddi »
Hi!
I have a problem starting zoneminder Service. It fails. The webapplication works so far.
apache (FTP, samba) runs as user Server, group Server.
I noticed some subdirectories (/var/log/zoneminder) are installed with user apache group apache.
Maybe there are some directories i have to change or chmod?
I do not know where to specify the Password for a su Server [FAILED SU (to Server) apache on none]
Server is in the sudoers group
Selinux is deactivated
● zoneminder.service - ZoneMinder CCTV recording and security system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fr 2016-05-20 10:30:07 CEST; 12s ago
Process: 4477 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
Mai 20 10:30:05 linux.fritz.box su[4513]: FAILED SU (to Server) apache on none
Mai 20 10:30:06 linux.fritz.box zmpkg.pl[4477]: Passwort: su: Fehler bei Aut...g
Mai 20 10:30:06 linux.fritz.box su[4561]: pam_unix(su:auth): auth could not ...]
Mai 20 10:30:06 linux.fritz.box su[4561]: FAILED SU (to Server) apache on none
Mai 20 10:30:07 linux.fritz.box zmpkg.pl[4477]: Passwort: su: Fehler bei Aut...g
Mai 20 10:30:07 linux.fritz.box zmpkg[4477]: ERR [Unable to find valid 'su' ...]
Mai 20 10:30:07 linux.fritz.box systemd[1]: zoneminder.service: control proc...5
Mai 20 10:30:07 linux.fritz.box systemd[1]: Failed to start ZoneMinder CCTV ....
Mai 20 10:30:07 linux.fritz.box systemd[1]: Unit zoneminder.service entered ....
Mai 20 10:30:07 linux.fritz.box systemd[1]: zoneminder.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
Re: FAILED SU (to Server) apache on none
So, I would guess you are using a red hat distro? If so, p!ease tell us what you used to install.
goddi
Post by goddi »
Hi!
I did download the Centos 7 64 Bit Image at the end of 2015 from the community.
For zoneminder i use it actually updated Centos 7 64 Bit on a "Biostar" Motherboard with a small AMD Atom like processor.
It is a clone of a Centos7 server prepared by me which runs stable on of some other servers / proccessors / motherboads for 6 months.
I did install Centos 7 / Apache / MYSQL / PHP / Samba / FTP / VNCSERVER from the original repositories - also ironcube ????? for an application.
Http / FTP / Samba work fine together. This runs for 6 month now with some web web applications. ( not used in this context).
Then i installed zoneminder.
I can startx and use Firefox on the "zoneminder" Server to connect.
