Zoneminder 1.28.1 on Debian 8
justong1979
Post by justong1979 »
I have been following the directions here for installing zoneminder on debian 8
and I go all the way through and when I try to access the web interface, i get the following error:
ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
What should I do?
Re: Zoneminder 1.28.1 on Debian 8
Looks like you installed ZM 1.29.0!
See here for the PHP edit: https://wiki.zoneminder.com/Debian_8_64 ... e_Easy_Way
or:
Add timezone to PHP
nano /etc/php5/apache2/php.ini
[Date]
Ctrl+o Enter to save
CTRL+x to exit
justong1979
Thank you. I got Zoneminder set up now.
I have successfully configured a USB camera, but I'm having problems with IP Camera running on an old android phone. The Feed is
10.16.24.57:8080/videofeed
and it works in another couple of programs, but in zoneminder all I'm getting is a blue image
Any suggestions?
likely your resolution settings are not right.
justong1979
Okay I'll try a few things. Thanks
