Page 1 of 1
Errors zm.mmap
Posted: Tue Jun 07, 2016 2:25 pm
by Angelo48
Hello everyone,
I would first apologize for my English.
Well, I started in there knowing nothing to linux and zoneminder. I installed on my PC X86 Fedora 23 and ZoneMinder 1.29. Zoneminder is started, and I installed cameras. Here is my problem. My cameras are in red, and in the log, I get errors as follows:
Memory map file "/dev/shm/zm.mmap1" does not exist. zmc might not be runnning.
Memory map file "/dev/shm/zm.mmap2" does not exist. zmc might not be runnning.
zmc -m 1 'exited abnormaly, exit status 127
zmc -m 2 'exited abnormaly, exit status 127
Is there someone who could help me? tell me what I forgot to do?
I thank you in advance.
Cordially.
Angelo
Re: Errors zm.mmap
Posted: Tue Jun 07, 2016 2:58 pm
by asker
Please take a look at the posting guidelines (How to Post)
You can start by providing that information, in detail and someone should be able to help
Re: Errors zm.mmap
Posted: Mon Jun 13, 2016 4:45 pm
by Angelo48
hi,
I solved my problem by using another app easy to use and works! And given the help I have received on this forum, so I explained that I did not speak English ..... You can close my post.
Angelo
