Logitech C615 - Only supports low resolution?
Posted: Sun Jul 03, 2016 2:32 pm
Hey there, I have a question about the available resolutions on my Logitech C615 camera.
I'm currently running Linux Mint 18 Cinnamon 64 bit, and I'm able to access my camera under /dev/video0, however only at low resolutions.
When I use the settings of: YUYV, I'm forced to use 176x144, and if I switch it to MJPEG, I can achieve 640x480. I'd like to be able to use 1280x720 for this camera as I've done with my windows installation using iSpy, but that doesn't seem to be possible. How am I able to use higher resolutions within linux/zoneminder? I noticed even when I access this camera under VLC or cheese, I'm only able to see the same resolutions. Is this a linux limitation?
Here's an output of: sudo zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: uvcvideo
Card: HD Webcam C615
Bus: usb-0000:00:1a.2-1.4
Version: 4.4.6
Type: 0x84200001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Does not support read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
YUYV 4:2:2 (YUYV)
Motion-JPEG (MJPG)
Crop Capabilities
Cropping is not supported
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
