I used this wiki page
https://wiki.zoneminder.com/How_to_get_ ... Zoneminder
And I could not understand what I must to change in zmfilter.pl I tried several times to make changes, but none option does not work. I do not understand the code enough to understand what the problem is, unfortunately.
Fragments of syslog:
Jul 9 06:52:56 debian rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="607" x-info="
http://www.rsyslog.com"] rsyslogd was HUPed
Jul 9 06:52:56 debian rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try
http://www.rsyslog.com/e/0 ]
Jul 9 06:52:56 debian rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try
http://www.rsyslog.com/e/2359 ]
Jul 9 06:55:01 debian CRON[8687]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jul 9 06:55:52 debian zmdc[1650]: INF [Starting pending process, zmfilter.pl]
Jul 9 06:55:52 debian zmdc[8689]: INF ['zmfilter.pl' started at 16/07/09 06:55:52]
Jul 9 06:55:52 debian zmdc[1650]: INF ['zmfilter.pl' starting at 16/07/09 06:55:52, pid = 8689]
Jul 9 06:55:53 debian zmdc[1650]: ERR ['zmfilter.pl' exited abnormally, exit status 9]
Jul 9 07:00:01 debian zmdc[1650]: INF [Starting pending process, zmc -m 3]
Jul 9 07:00:01 debian zmdc[1650]: INF ['zmc -m 3' starting at 16/07/09 07:00:01, pid = 8699]
Jul 9 07:00:01 debian zmdc[8699]: INF ['zmc -m 3' started at 16/07/09 07:00:01]
Jul 9 07:00:01 debian undef[8699]: INF [No Server ID or Name specified in config. Not using Multi-Server Mode.]
Jul 9 07:00:01 debian zmc[8699]: ERR [Bogus number of lines return from query, 0 returned for query select Id, Name, ServerId, Type, Function+0, Enabled, LinkedMonitors, Device, Channel, Format, V4LMultiBuffer, V4LCapturesPerFrame, Protocol, Method, Host, Port, Path, Options, User, Pass, Width, Height, Colours, Palette, Orientation+0, Deinterlacing, RTSPDescribe, Brightness, Contrast, Hue, Colour, EventPrefix, LabelFormat, LabelX, LabelY, LabelSize, ImageBufferCount, WarmupCount, PreEventCount, PostEventCount, StreamReplayBuffer, AlarmFrameCount, SectionLength, FrameSkip, MotionFrameSkip, AnalysisFPS, AnalysisUpdateDelay, MaxFPS, AlarmMaxFPS, FPSReportInterval, RefBlendPerc, AlarmRefBlendPerc, TrackMotion, SignalCheckColour, Exif from Monitors where Id = 3.]
Jul 9 07:00:01 debian zmc[8699]: ERR [Can't use query result: ]
Jul 9 07:00:01 debian zmdc[1650]: INF ['zmc -m 3' exited normally]
Jul 9 07:05:01 debian CRON[8707]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jul 9 07:05:53 debian zmdc[1650]: INF [Starting pending process, zmfilter.pl]
Jul 9 07:05:53 debian zmdc[8710]: INF ['zmfilter.pl' started at 16/07/09 07:05:53]
Jul 9 07:05:53 debian zmdc[1650]: INF ['zmfilter.pl' starting at 16/07/09 07:05:53, pid = 8710]
Jul 9 07:05:54 debian zmdc[1650]: ERR ['zmfilter.pl' exited abnormally, exit status 9]
Jul 9 07:09:01 debian CRON[8717]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Jul 9 07:10:01 debian zmdc[1650]: INF [Starting pending process, zmc -m 3]
Jul 9 07:10:01 debian zmdc[8750]: INF ['zmc -m 3' started at 16/07/09 07:10:01]
Jul 9 07:10:01 debian zmdc[1650]: INF ['zmc -m 3' starting at 16/07/09 07:10:01, pid = 8750]
Jul 9 07:10:01 debian undef[8750]: INF [No Server ID or Name specified in config. Not using Multi-Server Mode.]
Jul 9 07:10:01 debian zmc[8750]: ERR [Bogus number of lines return from query, 0 returned for query select Id, Name, ServerId, Type, Function+0, Enabled, LinkedMonitors, Device, Channel, Format, V4LMultiBuffer, V4LCapturesPerFrame, Protocol, Method, Host, Port, Path, Options, User, Pass, Width, Height, Colours, Palette, Orientation+0, Deinterlacing, RTSPDescribe, Brightness, Contrast, Hue, Colour, EventPrefix, LabelFormat, LabelX, LabelY, LabelSize, ImageBufferCount, WarmupCount, PreEventCount, PostEventCount, StreamReplayBuffer, AlarmFrameCount, SectionLength, FrameSkip, MotionFrameSkip, AnalysisFPS, AnalysisUpdateDelay, MaxFPS, AlarmMaxFPS, FPSReportInterval, RefBlendPerc, AlarmRefBlendPerc, TrackMotion, SignalCheckColour, Exif from Monitors where Id = 3.]
Jul 9 07:10:01 debian zmc[8750]: ERR [Can't use query result: ]
Jul 9 07:10:01 debian zmdc[1650]: INF ['zmc -m 3' exited normally]
Jul 9 07:15:01 debian CRON[8863]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
May be, I configured wrong filters for events? Screenshots attached
