zmaudit error in log
Posted: Thu Jul 21, 2016 4:33 am
Hello everyone,
It appears that I am getting a general zmaudit error in my log file every so often when I assume the zmaudit.pl tries to run.
Sure enough I have been having issues with my filters not running correctly and my disk ends up getting filled up to the point that the database crashes due to running out of space.
I then have to manually go in and remove files or try to delte database entries and "babysit" the system back to operation again.
What would cause the zmaudit.pl not to run properly ? Is there something I can check as far as permissions etc ?
Also, running the zmaudit.pl from root permissions on the command line into the server works fine....
