High resolution performance - need help
Posted: Sun Jul 24, 2016 1:05 pm
I just built a new very fast machine, and it cannot encode frames fast enough at higher resolutions. Is there anything I can do to improve it?
At 1920p (2592x1920) 32-bit color with the camera set to 15fps, I'm actually only getting about 2fps both recorded and in the live monitor. CPU load is between 2.5 and 3.1, the camera is streaming via RTP/RTSP and ffmpeg, 32-bit color. Enabling or disabling motion detection does not seem to change the fps. The live monitor shows the same frame rate as what is recorded. The problem improves as I lower the resolution, but I'm all the way down to 1080p before I get anything close to 15fps recorded. There are only 2 cameras on the machine, one at 920p 7fps (MicroSeven) and one at 1920p 15fps (5MP).
The machine is a 6-core i7 @3.3GHz, 16GB quad channel DDR4 RAM 2666MHz, pair of Western Digital Se hard disks. Linux shows 12 cores available, CPU load varies between about 2.5 and 3.1. The log below is of me setting the ZM state to "Running" then walking in front of the 1920p camera to cause a motion event. I tried to attach it as a file but the forum seems to not allow me to attach a .txt or .log file.
Any tips would be greatly appreciated!
Date/Time
Component Server PID Level Message File Line
2016-07-24 08:55:32.285427 zma_m1 7994 INF MicroSeven: 1000 - Analysing at 6.94 fps zm_monitor.cpp 1287
2016-07-24 08:55:29.832510 zmc_m1 7957 INF MicroSeven: 1000 - Capturing at 6.90 fps zm_monitor.cpp 3131
2016-07-24 08:55:19.176225 zmc_m2 7956 INF 5MP: 2000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-07-24 08:54:53.866361 zma_m2 7995 INF 5MP: 1000 - Analysing at 9.52 fps zm_monitor.cpp 1287
2016-07-24 08:54:21.637180 zms 8022 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-07-24 08:54:12.510485 zmc_m2 7956 INF 5MP: 1000 - Capturing at 14.71 fps zm_monitor.cpp 3131
2016-07-24 08:54:08.560331 undef 8022 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:12.850037 zma_m1 7994 INF MicroSeven: 026 - Opening new event 131, section start zm_monitor.cpp 1532
2016-07-24 08:53:10.425828 zma_m1 7994 INF In mode 5/1, warming up zma.cpp 142
2016-07-24 08:53:09.369771 zma_m1 7994 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-07-24 08:53:08.978599 zma_m2 7995 INF 5MP: 026 - Opening new event 130, section start zm_monitor.cpp 1532
2016-07-24 08:53:08.578349 zma_m2 7995 INF In mode 5/1, warming up zma.cpp 142
2016-07-24 08:53:08.450862 undef 7995 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:08.329830 zmdc 7995 INF 'zma -m 2' started at 16/07/24 08:53:08 zmdc.pl
2016-07-24 08:53:08.329780 zmdc 7901 INF 'zma -m 2' starting at 16/07/24 08:53:08, pid = 7995 zmdc.pl
2016-07-24 08:53:08.302338 zma_m1 7994 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-07-24 08:53:08.236090 zmdc 7901 INF Starting pending process, zma -m 2 zmdc.pl
2016-07-24 08:53:08.230874 undef 7994 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:08.146220 zmdc 7994 INF 'zma -m 1' started at 16/07/24 08:53:08 zmdc.pl
2016-07-24 08:53:08.146210 zmdc 7901 INF 'zma -m 1' starting at 16/07/24 08:53:08, pid = 7994 zmdc.pl
2016-07-24 08:53:08.035150 zmdc 7901 INF Starting pending process, zma -m 1 zmdc.pl
2016-07-24 08:53:04.759958 zmc_m2 7956 INF Priming capture from rtsp://192.168.1.86:554/h264?username=admin&password=demo321 zm_ffmpeg_camera.cpp 104
2016-07-24 08:53:04.733101 zmc_m2 7956 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-07-24 08:53:04.517810 zmwatch 7963 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-07-24 08:53:04.517799 zmc_m1 7957 INF Priming capture from rtsp://root:yz80yz80microseven!!@192.168.1.83:554/11 zm_ffmpeg_camera.cpp 104
2016-07-24 08:53:04.408780 zmwatch 7963 INF Watchdog starting zmwatch.pl
2016-07-24 08:53:04.347522 zmc_m1 7957 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-07-24 08:53:04.293200 zmdc 7963 INF 'zmwatch.pl' started at 16/07/24 08:53:04 zmdc.pl
2016-07-24 08:53:04.293190 zmdc 7901 INF 'zmwatch.pl' starting at 16/07/24 08:53:04, pid = 7963 zmdc.pl
2016-07-24 08:53:04.186990 zmfilter 7941 INF Scanning for events zmfilter.pl
2016-07-24 08:53:04.152529 undef 7957 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:04.069270 zmdc 7958 INF 'zmaudit.pl -c' started at 16/07/24 08:53:04 zmdc.pl
2016-07-24 08:53:04.069250 zmdc 7901 INF 'zmaudit.pl -c' starting at 16/07/24 08:53:04, pid = 7958 zmdc.pl
2016-07-24 08:53:04.010760 zmdc 7901 INF 'zmc -m 1' starting at 16/07/24 08:53:04, pid = 7957 zmdc.pl
2016-07-24 08:53:04.010760 zmdc 7957 INF 'zmc -m 1' started at 16/07/24 08:53:04 zmdc.pl
2016-07-24 08:53:03.933530 zmdc 7901 INF Starting pending process, zmc -m 1 zmdc.pl
2016-07-24 08:53:03.914356 undef 7956 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:03.875170 zmdc 7901 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:03.759080 zmdc 7956 INF 'zmc -m 2' started at 16/07/24 08:53:03 zmdc.pl
2016-07-24 08:53:03.759070 zmdc 7901 INF 'zmc -m 2' starting at 16/07/24 08:53:03, pid = 7956 zmdc.pl
2016-07-24 08:53:03.707936 zma_m1 7955 ERR Shared data not initialised by capture daemon for monitor MicroSeven zm_monitor.cpp 442
2016-07-24 08:53:03.656880 zmdc 7901 INF Starting pending process, zmc -m 2 zmdc.pl
2016-07-24 08:53:03.636723 undef 7955 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:03.598390 zmdc 7901 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:03.466820 zmdc 7955 INF 'zma -m 1' started at 16/07/24 08:53:03 zmdc.pl
2016-07-24 08:53:03.466790 zmdc 7901 INF 'zma -m 1' starting at 16/07/24 08:53:03, pid = 7955 zmdc.pl
2016-07-24 08:53:03.374064 zma_m2 7954 ERR Shared data not initialised by capture daemon for monitor 5MP zm_monitor.cpp 442
2016-07-24 08:53:03.297910 zmdc 7901 INF Starting pending process, zma -m 1 zmdc.pl
2016-07-24 08:53:03.278659 undef 7954 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:03.166330 zmdc 7901 INF 'zma -m 2' starting at 16/07/24 08:53:03, pid = 7954 zmdc.pl
2016-07-24 08:53:03.166330 zmdc 7954 INF 'zma -m 2' started at 16/07/24 08:53:03 zmdc.pl
2016-07-24 08:53:03.105900 zmdc 7901 INF Starting pending process, zma -m 2 zmdc.pl
2016-07-24 08:53:03.022430 zmdc 7901 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:02.947370 zmdc 7901 ERR 'zma -m 1' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:02.905540 zmdc 7901 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:02.826570 zmdc 7901 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-07-24 08:53:02.822962 zma_m1 7929 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 533
2016-07-24 08:53:02.781049 zma_m2 7937 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 533
2016-07-24 08:53:02.767369 undef 7929 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:02.767321 undef 7933 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:02.730737 undef 7925 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:02.729723 undef 7937 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-07-24 08:53:02.729370 zmdc 7901 INF 'zmfilter.pl' starting at 16/07/24 08:53:02, pid = 7941 zmdc.pl
2016-07-24 08:53:02.729370 zmdc 7941 INF 'zmfilter.pl' started at 16/07/24 08:53:02 zmdc.pl
2016-07-24 08:53:02.441510 zmdc 7937 INF 'zma -m 2' started at 16/07/24 08:53:02 zmdc.pl
2016-07-24 08:53:02.441130 zmdc 7901 INF 'zma -m 2' starting at 16/07/24 08:53:02, pid = 7937 zmdc.pl
2016-07-24 08:53:02.187840 zmdc 7933 INF 'zmc -m 2' started at 16/07/24 08:53:02 zmdc.pl
2016-07-24 08:53:02.187820 zmdc 7901 INF 'zmc -m 2' starting at 16/07/24 08:53:02, pid = 7933 zmdc.pl
2016-07-24 08:53:01.924500 zmdc 7929 INF 'zma -m 1' started at 16/07/24 08:53:01 zmdc.pl
2016-07-24 08:53:01.924440 zmdc 7901 INF 'zma -m 1' starting at 16/07/24 08:53:01, pid = 7929 zmdc.pl
2016-07-24 08:53:01.704340 zmdc 7901 INF 'zmc -m 1' starting at 16/07/24 08:53:01, pid = 7925 zmdc.pl
2016-07-24 08:53:01.704320 zmdc 7925 INF 'zmc -m 1' started at 16/07/24 08:53:01 zmdc.pl
2016-07-24 08:53:01.519410 zmpkg 7885 INF Starting up services zmpkg.pl
2016-07-24 08:52:58.515560 zmdc 7901 INF Server starting at 16/07/24 08:52:58 zmdc.pl
2016-07-24 08:52:58.220430 zmpkg 7885 INF Command: start zmpkg.pl
2016-07-24 08:52:58.177590 zmpkg 7885 INF Sanity checking States table... zmpkg.pl
2016-07-24 08:52:58.003180 zmsystemctl 7876 INF Redirecting command through systemctl zmsystemctl.pl
2016-07-24 08:52:57.770180 zmpkg 7870 INF Command: start zmpkg.pl
2016-07-24 08:52:57.726260 zmpkg 7870 INF Sanity checking States table... zmpkg.pl
Date/Time
