POrting ZM
rfeyer
POrting ZM
Post by rfeyer »
Hi all,
Finally have ZM working - had to change Mint 17 to Ubuntu 16.04 and all worked quite well!
Am able to find the GUI over LAN with ip_address/zm
I have been looking through the options menus to see if there is a port allocation but could not find one. I am new to Linux, so I am not sure if it works the same - can ZM be configured for a specific port which I then can forward with the modem which I then can access over internet?
Rainer
Re: POrting ZM
ZM runs in Apache which is a web server. Default web server port is 80.
rfeyer
Re: POrting ZM
Post by rfeyer »
Ty vm for answer
Is there a way to assign a different port to zm?
mikb
Re: POrting ZM
Post by mikb »
You will have to look at your APACHE server configuration (or any bits that Apache imports from Zoneminder in addition to your standard httpd.conf file).
It is Apache that controls what port the ZM interface appears on.
gnocera
Re: POrting ZM
Post by gnocera »
Probably you will have to edit the file
/etc/apache2/ports.conf
and you will have to add a Listen xxx where xxx is the port number you want to enable, for instance
Listen 8080
After you save the file you will have to execute the following command from terminal:
sudo service apache2 restart
You can now point your browser at http://your_server_IP:xxx/zm
and you will have zoneminder working on port xxx
Notice that you can listen multiple ports (multiple listen lines) that means you can remain the port 80 and add others at your convenience.
Regards.
