dedicated hard drive
alabamatoy
Post by alabamatoy »
I followed these instructions (with some necessary tweaks) https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
The drive is mounted, fstab appears to be correct, ownership is www-data but nothing appears in either events or images folders, and ZM appears to be happily writing stuff to /var/cache/zoneminder folders.
fstab:
/dev/sdb1 /zmdata ntfs defaults,umask=007,uid=33,gid=33 0 2
/zmdata/images /var/cache/zoneminder/images none defaults,bind 0 2
/zmdata/events /var/cache/zoneminder/events none defaults,bind 0 2
gid/uid is www-data
What have I missed?
gnocera
Re: dedicated hard drive
Post by gnocera »
What about your log? On the upper right side of the zoneminder main window.
What Linux distribution are you using?
Please post the df output also.
Regards.
evolotion
Post by evolotion »
did you mount -a to apply your changes to fstab?
did you try mounting the zmdata folder without the umask/uid/gid?
Just went thro this myself a few minutes ago and worked fine :/
alabamatoy
I gave up on this. There was something amiss in the NTFS and the associated permissions and rights etc....no matter what I did or tried it wouldnt seem to work. So I did the Ubuntu thing and gave M$ the finger and reformatted the whole bleeping drive (both of them) and started over from scratch. So now Im committed to Linux and really can't go back. Even if I wanted to, which I really dont at this point.
The surprising thing was, it took me about 2 hours to do what took me far longer the first time around. I have a nice happy 16.04 LTS running 1.29 zoneminder storing stuff on a secondary HDD and log files that are mostly just nothing but good news. (does little victory dance)
Thanks for all the help. This forum is great, every time I ask stupid questions yall help me out.
