In case you have problems on the verge of FFMPEG and RTSP (well described under this link https://wiki.zoneminder.com/Doing_your_ ... pe:_FFMPEG) you may try the following:
In case you use libav-tools:
apt-get remove --purge libav-tools
deb http://www.deb-multimedia.org jessie main non-free
deb-src http://www.deb-multimedia.org jessie main non-free
apt-get update
apt-get install deb-multimedia-keyring
apt-get update
apt-get install libav-tools
However god knows for how long it will work fine.
Last but not least, I run Anran rtsp camera at 3fps, having Alarm Frame Count set at 3 as well.
System is 32bit armhf Debian jessie.
