Zoneminder stopped after upgrade to 1.30
AndresCT46
Post by AndresCT46 »
Hi, good day
We are having trouble with zoneminder stopped.
2 server, both with Ubuntu 14.04 lts, both with zoneminder 1.29.0, both stopping with similar socket errors.
Each server has 16-cores (2 x CPU AMD Opteron 4000 8-core ), 16GB RAM, 8TB disk and around 70 HD H264 cameras.
We didn't have those problems with zoneminder 1.28. Problem just started with ZM 1.29.0
We decided to upgrade because we did some test with 1.29 and we realized that 1.29 save some resources from the CPU, so CPU run more smoother.
But unfortunately Zoneminder stops suddenly.
In recent days we made the upgrade to version 1.30 , but still with error of socket and Zonemider stop :cry: .
We appreciate any help.
I attach error log ZoneMinder today.
Thank you.
zm_log_server_1_09-08-2016.zip
(1.7 KiB) Downloaded 369 times
gnocera
Re: Zoneminder stopped after upgrade to 1.30
Post by gnocera »
Here is some error that we think are involved in the issue. Here are a few error, SOCKET ERROR is definitively an issue.
You can see a large file attached with more errors.
This was not happening in ZM 1.28. It started to happen in 1.29 ans also 1.30
Regards.
2016-08-02 07:37:39.735971 web_php 11881 ERR socket_sendto( /var/run/zm/zms-004202s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:39.765740 web_php 11884 ERR socket_sendto( /var/run/zm/zms-165481s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:43.110387 web_php 12223 ERR socket_sendto( /var/run/zm/zms-482052s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:43.159001 web_php 11881 ERR socket_sendto( /var/run/zm/zms-359509s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:45.314307 web_php 12223 ERR socket_sendto( /var/run/zm/zms-187399s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:45.349743 web_php 11881 ERR socket_sendto( /var/run/zm/zms-304256s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:49.876702 web_php 12223 ERR socket_sendto( /var/run/zm/zms-203635s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:49.906263 web_php 11881 ERR socket_sendto( /var/run/zm/zms-426576s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:51.971947 web_php 11846 ERR socket_sendto( /var/run/zm/zms-711401s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:52.042524 web_php 12223 ERR socket_sendto( /var/run/zm/zms-969208s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:54.029451 web_php 11846 ERR socket_sendto( /var/run/zm/zms-979538s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:54.102244 web_php 12223 ERR socket_sendto( /var/run/zm/zms-524180s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:56.190708 web_php 11846 ERR socket_sendto( /var/run/zm/zms-075385s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:56.262168 web_php 12223 ERR socket_sendto( /var/run/zm/zms-163390s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:58.314821 web_php 12223 ERR socket_sendto( /var/run/zm/zms-029169s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:37:58.496124 web_php 11846 ERR socket_sendto( /var/run/zm/zms-680609s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:38:00.383190 web_php 12223 ERR socket_sendto( /var/run/zm/zms-665914s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-08-02 07:38:00.541457 web_php 11846 ERR socket_sendto( /var/run/zm/zms-328870s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
log 6 Ago 2016.zip
(253.23 KiB) Downloaded 265 times
Socket sento errors do not always mean you have a serious problem. My production server gets them all the time but the server keeps chugging along.
Your ZM stopping could be an indication that you are running out of memory. With all those cameras your /run/shm may be full which is where you have the PATH_SWAP set to. You may want to set PATH_SWAP back to /tmp/zm to see if this helps. Lowering resolution may help the memory issue. Also check the MySQL innodb_buffer_pool_size. Better yet install and run mysqltuner and make adjustments accordingly.
PATH_MAP, PATH_SOCKS and PATH_SWAP are recommended to be run from tmpfs as RAM is faster than a hard drive. You can change all three to /tmp and see what happens and move them back to tmpfs one at a time.
Hope this is on the right track..
gnocera
Post by gnocera »
Thank you for help. We will double check the parameters and we will come back here. More hints from you are very welcome. ;-)
PATH SWAP is already pointing to /tmp/zm
MySQL innodb_buffer_pool_size is set to 8G on both servers
We have 70 monitors (on each server), each monitor configured as MODECT, ffmpeg, RTP/RTSP 640x360, 6 fps, 24 bit color. In the buffer tab we have 50,25,25,25 as default
OK got it we will run mysqltuner to see what is going on the db basement.
What is really a strange behavior it is the fact that on Zoneminder 1.28 version it was working fine and stable.
Regards.
SteveGilvarry
Post by SteveGilvarry »
Didn't see any mention of this yet. Recent changes to zm package on ubuntu for cgi-path in apache conf
http://zoneminder.readthedocs.io/en/sta ... -streaming
PATH_ZMS /zm/cgi-bin/nph-zms is the most common fix, but check apache.conf script alias path matches.
"Operation now in progress" I have normally seen when the camera is maxed out on multiple streams, i.e. opening a direct stream to it while zm is running or running multiple zm's pointing at it. Different cameras cope better with that than others.
SteveGilvarry
Some also advise 32-bit colour is more efficient, I forget why.
Because 32 bit uses SSE2 instruction set, which is a lot faster.
If I recall, the speed improvements require the colorspace to be a power of 2 so bit shifting could be used, rather than division, for the operations. Thus 32bit colorspace was born.
gnocera
Post by gnocera »
Hello, this is the apache2.conf file content
___________________________________________
Remember to enable cgi mod (i.e. "a2enmod cgi").
AllowOverride All
Require all granted
</Directory>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
_______________________________________________
Then we check PATH_ZMS is pointing to /zm/cgi-bin/nph-zms
SteveGilvarry wrote:Didn't see any mention of this yet. Recent changes to zm package on ubuntu for cgi-path in apache conf
Well it would be wonderful if we had a way to make the montage view of 70 cameras with the stream 2 (mean 320x180), and when we click on any live image of any camera it would be great if it could be open (big) with the full resolution (mean stream 0 1280x720). But we do not know if is it possible on this version ZM 1.30
Regards.
gnocera
Post by gnocera »
knnniggett wrote:Because 32 bit uses SSE2 instruction set, which is a lot faster.
Hello, we set all 32bit colors, also remove the -"- from the zoneminder.conf like other posts said.
Here is the result of df -h
df -h
Filesystem Size Used Avail Use% Mounted on
udev 7.8G 4.0K 7.8G 1% /dev
tmpfs 1.6G 592K 1.6G 1% /run
/dev/sda1 55G 18G 35G 34% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
none 5.0M 0 5.0M 0% /run/lock
none 7.9G 2.4G 5.6G 30% /run/shm
none 100M 0 100M 0% /run/user
/dev/sda5 28G 44M 26G 1% /home
/dev/md0 5.5T 2.6T 2.7T 49% /usr
Unfortunately today server stopped again, this is the last error alarms. :-(
2016-08-26 02:43:09.821490 zmc_m42 19303 FAT Unable to decode frame at frame 302711 zm_ffmpeg_camera.cpp 178
2016-08-26 02:26:03.042436 zms 21745 ERR Unable to send raw frame 59: Broken pipe zm_event.cpp 1332
2016-08-26 02:12:03.168259 zms 19515 ERR Unable to send raw frame 58: Broken pipe zm_event.cpp 1332
2016-08-26 02:06:55.459256 zms 18131 ERR Unable to send raw frame 58: Broken pipe zm_event.cpp 1332
2016-08-26 02:04:42.954763 zms 17910 ERR Unable to send raw frame 106: Broken pipe zm_event.cpp 1332
2016-08-26 01:12:07.997365 zms 10773 ERR Unable to send raw frame 95: Broken pipe zm_event.cpp 1332
2016-08-25 19:15:27.239320 zmwatch 20238 ERR Unable to run "/usr/bin/zmdc.pl restart zma -m 25", output is "Unable to connect to server" zmwatch.pl
2016-08-25 19:15:27.002980 zmwatch 20238 ERR Error getting last capture time for 1Er_Piso_Torre_6 zmwatch.pl
2016-08-25 18:28:30.884777 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:28:19.856518 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:28:10.556877 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:59.388975 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:49.376628 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:39.364822 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:29.353041 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:19.344630 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:27:09.332497 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:59.320368 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:49.312971 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:39.300696 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:29.288333 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:19.276348 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:11.888668 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:26:00.684351 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:25:49.363502 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:25:39.348362 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:25:29.336782 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:25:19.328729 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:25:09.316402 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:59.305049 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:52.872706 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:41.052975 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:29.144519 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:19.130126 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:24:09.116450 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:59.104785 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:49.088803 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:39.080362 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:29.068821 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:19.056844 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:23:09.048636 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:59.032664 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:49.020712 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:40.008761 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:29.992325 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:19.980477 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:22:09.968584 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:59.956554 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:49.944631 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:39.936694 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:29.916682 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:19.908418 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:21:09.896335 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:59.880820 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:49.868320 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:39.856441 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:29.844905 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:21.832328 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:20:10.868652 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:59.168693 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:49.152476 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:39.140489 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:29.125100 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:20.116520 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:19:11.200498 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:59.852372 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:49.840345 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:39.824423 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:29.816398 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:19.804697 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:18:09.792466 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:17:59.772895 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:17:49.760390 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:17:39.748690 zmc_m3 14474 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:17:29.736512 zmc_m3 14441 ERR Unable to open input rtsp://admin:admin@192.168.1.104:554/12 due to: Operation now in progress zm_ffmpeg_camera.cpp 280
2016-08-25 18:17:20.363546 zms 10371 ERR Terminating, last frame sent time 10.099715 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2016-08-25 18:17:07.823049 zmc_m40 19266 ERR Unable to read packet from stream 0: error -1606004923 "End of file". zm_ffmpeg_camera.cpp 167
2016-08-25 18:14:05.749371 zmc_m52 19609 ERR Unable to read packet from stream 0: error -1606004923 "End of file". zm_ffmpeg_camera.cpp 167
2016-08-25 18:07:52.030894 zmc_m20 13171 ERR Unable to open input rtsp://192.168.1.186:554/user=admin&password=&channel=1&stream=2 due to: Success zm_ffmpeg_camera.cpp 280
2016-08-25 18:07:52.019083 zmc_m20 13171 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2016-08-25 18:03:24.029460 zmwatch 20238 ERR Error getting last capture time for Porteria_No_2 zmwatch.pl
2016-08-25 18:03:13.599220 zmwatch 20238 ERR Error getting last capture time for Porteria_No_2 zmwatch.pl
2016-08-25 18:01:21.304399 zms 10398 ERR Terminating, last frame sent time 10.009671 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2016-08-25 17:33:22.028008 web_php 10812 ERR socket_sendto( /var/run/zm/zms-459481s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:20.329076 web_php 20533 ERR socket_bind( /var/run/zm/zms-459481w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:19.899001 zms 9271 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:19.863239 zms 9269 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:19.828507 web_php 6054 ERR socket_sendto( /var/run/zm/zms-812827s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:19.699672 zms 9264 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:19.660961 zms 9262 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:19.620568 web_php 20533 ERR socket_sendto( /var/run/zm/zms-407525s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:17.442289 zms 9232 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:17.392424 zms 9230 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:17.360286 zms 9227 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:17.297944 web_php 7324 ERR socket_sendto( /var/run/zm/zms-662279s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:17.023949 zms 9221 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:16.993608 zms 9219 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:16.954810 web_php 7326 ERR socket_sendto( /var/run/zm/zms-459481s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-25 17:33:14.939078 zms 9191 ERR Unable to authenticate user zms.cpp 225
2016-08-25 17:33:14.890650 zms 9189 ERR Unable to authenticate user zms.cpp 225
chebo
Post by chebo »
I have a similar problem. At 1.30 ZM himself became a stop.
And the log file is not conducted with me. Directory /var /log /zm absent. I tried to create it by hand, but the log files are not created. The default variable PATH_LOGS = /var /log /zm
chebo wrote:I have a similar problem. At 1.30 ZM himself became a stop.
Click "log" from the web console
chebo
Post by chebo »
knnniggett wrote: Click "log" from the web console
In this case, the depth of the log is severely limited. Or not?
Zoneminder can stay the night, and the rows are overwritten.
chebo
Post by chebo »
AndresCT46 wrote:Hi, good day
Did you find a solution?
gnocera
Post by gnocera »
Unfortunately we still have not found the solution. Zoneminder continues to stop with no apparently reason.
Recently we upgrade the RAM memory of the server until 24 GB and we changed the parameter "vm.swappiness=30" in order to avoid Ubuntu to swap less frequently.
We have 2 similar servers, each one with 16 cores, 24 GB RAM, 1 SSD disk of 120GB for Ubuntu operating system, plus 8TB in a RAID 5 for record files.
Each server handle 70 ffmpeg HD H264 cameras.
But it stops and we do not know the reason.
Regards,
GNC
That URL for rtsp://admin:admin@192.168.1.104:554/12 looks suspicious to me and the Operation now in progress part means that ffmpeg is unable to connect to the camera.
As to ZoneMinder stopping, the reason why will be in the logs... but you havn't really shown us any of the relevant logs. ZoneMinder can stop for many reasons, one of which is mysql stopping. So we need more information.
I also recommend using monit to ensure that it starts back up if it does stop.
