stream error: socket_sendto PROBLEM
Posted: Fri Aug 19, 2016 1:01 pm
I have a serious problem after upgrading to 1.30 from version 1.28.
I can no longer see the streaming of the cameras . I uninstalled and reinstalled everything several times but got nothing .
the cameras work and zoneminder records disk images when it is active , but if I want to see streaming I have this error:
getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-065701s.sock ) failed: No such file or directory - checkStreamForErrors()
I searched the interent the various issues regarding this bug , but I failed in any way to solve it . I copy cambozolla in / usr / share / zoneminder / www by running chmod 777 and chown www-data : www-data on it hoping it works, but nothing .
I desperately need help !!
