Latest zmrepo 08/16 install fails on RHEL 7.2 Server
Anybody else get this err
Poll ended at Wed Aug 31, 2016 2:14 am
Yes
0
No votes
No
0
No votes
Total votes: 0
Jazzzzz
Post by Jazzzzz »
Hayloo,
I am trying to install zmrepo 1.3 or latest release on latest RHEL7 but get the errors below:
Followed the instructions on zmrepo site to try to install but ...
The URL for 7Server should be 7 but I haven't been able to fix the script.
Because zmrepo is meant to install on rhel 7 out of the box, I don't want to play with it because I need to be able to package it up later.
My repos are purely redhat so I believe the system is 'clean,'
and it does not exhibit any problems when running yum update.
The error message points to the missing file but the message leads to repo gets that don't work because rhel is setup to use Classic and RHSM subscriptions. But my system is only using subscription-manager and is not setup to use the classic subscription.
I searched the forums and web but nottathing I could find to resolve this.
Are there scripts for installing zmrepo on RHEL 7.2 Server?
Or please help me fix this error.
Jazzzzz
After running CDs on zmrepo site without issues I ran install zoneminder as below
[zm]$ sudo yum install zoneminder
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-
: manager
http://zmrepo.connortechnology.com/el/7 ... repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/articles/1320623
If above article doesn't help to resolve this issue please open a ticket with Red Hat Support.
http://67.53.78.182/el/7Server/x86_64/r ... repomd.xml: [Errno 14] HTTP Error 404 - Not Found
zmrepo | 13 kB 00:00
http://zmrepo.mehvc.com/el/7Server/x86_ ... repomd.xml: [Errno -1] Error importing repomd.xml for zmrepo: Damaged repomd.xml file
One of the configured repositories failed (Zoneminder and its dependencies for Enterprise Linux 7Server - x86_64),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Disable the repository, so yum won't use it by default. Yum will then
just ignore the repository until you permanently enable it again or use
--enablerepo for temporary usage:
yum-config-manager --disable zmrepo
4. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=zmrepo.skip_if_unavailable=true
failure: repodata/repomd.xml from zmrepo: [Errno 256] No more mirrors to try.
[zm]$
Re: Latest zmrepo 08/16 install fails on RHEL 7.2 Server
Moved to the ZoneMinder 1.30.0 forum.
abauer@techeng-wks01:~$ wget http://zmrepo.connortechnology.com/el/7Server/x86_64/repodata/repomd.xml
--2016-08-25 10:52:37--  http://zmrepo.connortechnology.com/el/7Server/x86_64/repodata/repomd.xml
Resolving zmrepo.connortechnology.com (zmrepo.connortechnology.com)... 69.165.169.197
Connecting to zmrepo.connortechnology.com (zmrepo.connortechnology.com)|69.165.169.197|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2993 (2.9K) [application/xml]
Saving to: ‘repomd.xml’
repomd.xml          100%[===================>]   2.92K  --.-KB/s    in 0.001s
2016-08-25 10:52:37 (3.80 MB/s) - ‘repomd.xml’ saved [2993/2993]
Try it again. It should work now.
Jazzzzz
Post by Jazzzzz »
Tried it again and notta workin, below is yum install textg
Found fribidi library for RHEL7 in place of libfribidi but install still fails this way.
Found that vlc has a lot of the libaries that are used but it won't install either
What Lunix verison would be more open and less restrictive because I am running into the redhat repo limitations big time but need to be more productive. I picked RHEL this time around because I used it a lot way back in time like up to v3.
Or is there an easier way to resolve dependencies that RHEL has and get versions that will work?
James
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-manager
Resolving Dependencies
--> Running transaction check
---> Package zoneminder.x86_64 0:1.30.0-4.el7.centos will be installed
--> Processing Dependency: vlc-core for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: php-mysql for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: php-gd for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: php for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(version) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(X10::ActiveHome) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(URI::Encode) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Sys::Syslog) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Sys::Mmap) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Sys::MemInfo) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Sys::CPU) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::ComplexType) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::Builtin::anyType) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::Builtin::anySimpleType) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::Builtin) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::XSD::Typelib::AttributeSet) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Transport::HTTP) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::SOAP::Typelib::Fault11) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Transport) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Serializer) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Factory::Deserializer) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Expat::MessageParser) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Deserializer::XSD) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(SOAP::WSDL::Client::Base) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Module::Load::Conditional) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(MIME::Lite) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(MIME::Entity) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(LWP::Protocol::https) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(IO::Socket::Multicast) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Device::SerialPort) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Date::Manip) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Data::UUID) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Data::Dump) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(DBD::mysql) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Class::Std::Fast::Storable) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Class::Std::Fast) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Archive::Zip) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: perl(Archive::Tar) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: mariadb-server for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libswscale.so.3(LIBSWSCALE_3)(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libmysqlclient.so.18(libmysqlclient_18)(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavutil.so.54(LIBAVUTIL_54)(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavformat.so.56(LIBAVFORMAT_56)(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavcodec.so.56(LIBAVCODEC_56)(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: httpd for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: ffmpeg for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: cambozola for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libvlc.so.5()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libswscale.so.3()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libmysqlclient.so.18()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavutil.so.54()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavformat.so.56()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavdevice.so.56()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
--> Processing Dependency: libavcodec.so.56()(64bit) for package: zoneminder-1.30.0-4.el7.centos.x86_64
---> Package cambozola.noarch 0:0.93-1.el7.centos will be installed
---> Package ffmpeg.x86_64 0:2.8.7-1.el7.centos will be installed
--> Processing Dependency: libvdpau.so.1()(64bit) for package: ffmpeg-2.8.7-1.el7.centos.x86_64
---> Package ffmpeg-libs.x86_64 0:2.8.7-1.el7.centos will be installed
--> Processing Dependency: libxvidcore.so.4()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libx265.so.68()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libx264.so.148()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libva.so.1()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libsoxr.so.0()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libschroedinger-1.0.so.0()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libmp3lame.so.0()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libass.so.5()(64bit) for package: ffmpeg-libs-2.8.7-1.el7.centos.x86_64
---> Package httpd.x86_64 0:2.4.6-40.el7_2.4 will be installed
--> Processing Dependency: httpd-tools = 2.4.6-40.el7_2.4 for package: httpd-2.4.6-40.el7_2.4.x86_64
---> Package libavdevice.x86_64 0:2.8.7-1.el7.centos will be installed
--> Processing Dependency: libopenal.so.1()(64bit) for package: libavdevice-2.8.7-1.el7.centos.x86_64
--> Processing Dependency: libdc1394.so.22()(64bit) for package: libavdevice-2.8.7-1.el7.centos.x86_64
---> Package mariadb-libs.x86_64 1:5.5.50-1.el7_2 will be installed
---> Package mariadb-server.x86_64 1:5.5.50-1.el7_2 will be installed
--> Processing Dependency: mariadb(x86-64) = 1:5.5.50-1.el7_2 for package: 1:mariadb-server-5.5.50-1.el7_2.x86_64
---> Package perl-Archive-Tar.noarch 0:1.92-2.el7 will be installed
--> Processing Dependency: perl(IO::Zlib) >= 1.01 for package: perl-Archive-Tar-1.92-2.el7.noarch
--> Processing Dependency: perl(IO::Zlib) for package: perl-Archive-Tar-1.92-2.el7.noarch
--> Processing Dependency: perl(Package::Constants) for package: perl-Archive-Tar-1.92-2.el7.noarch
---> Package perl-Archive-Zip.noarch 0:1.30-11.el7 will be installed
---> Package perl-Class-Std-Fast.noarch 0:0.0.8-2.el7.centos will be installed
--> Processing Dependency: perl(Class::Std) for package: perl-Class-Std-Fast-0.0.8-2.el7.centos.noarch
---> Package perl-DBD-MySQL.x86_64 0:4.023-5.el7 will be installed
---> Package perl-Data-Dump.noarch 0:1.22-1.el7 will be installed
---> Package perl-Data-UUID.x86_64 0:1.219-3.el7 will be installed
---> Package perl-Date-Manip.noarch 0:6.41-2.el7 will be installed
---> Package perl-Device-SerialPort.x86_64 0:1.04-5.el7.centos will be installed
---> Package perl-IO-Socket-Multicast.x86_64 0:1.12-1.el7.centos will be installed
--> Processing Dependency: perl(IO::Interface) >= 0.94 for package: perl-IO-Socket-Multicast-1.12-1.el7.centos.x86_64
---> Package perl-LWP-Protocol-https.noarch 0:6.04-4.el7 will be installed
--> Processing Dependency: perl(Mozilla::CA) >= 20110101 for package: perl-LWP-Protocol-https-6.04-4.el7.noarch
---> Package perl-MIME-Lite.noarch 0:3.030-1.el7 will be installed
--> Processing Dependency: perl(MIME::Types) >= 1.28 for package: perl-MIME-Lite-3.030-1.el7.noarch
--> Processing Dependency: perl(Email::Date::Format) for package: perl-MIME-Lite-3.030-1.el7.noarch
---> Package perl-MIME-tools.noarch 0:5.505-1.el7 will be installed
--> Processing Dependency: perl(Mail::Internet) >= 1.28 for package: perl-MIME-tools-5.505-1.el7.noarch
--> Processing Dependency: perl(Mail::Header) >= 1.09 for package: perl-MIME-tools-5.505-1.el7.noarch
--> Processing Dependency: perl(Mail::Field) >= 1.05 for package: perl-MIME-tools-5.505-1.el7.noarch
--> Processing Dependency: perl(Mail::Send) for package: perl-MIME-tools-5.505-1.el7.noarch
--> Processing Dependency: perl(Mail::Field) for package: perl-MIME-tools-5.505-1.el7.noarch
--> Processing Dependency: perl(Convert::BinHex) for package: perl-MIME-tools-5.505-1.el7.noarch
---> Package perl-Module-Load-Conditional.noarch 0:0.54-3.el7 will be installed
--> Processing Dependency: perl(Module::CoreList) >= 2.22 for package: perl-Module-Load-Conditional-0.54-3.el7.noarch
--> Processing Dependency: perl(Module::Load) >= 0.11 for package: perl-Module-Load-Conditional-0.54-3.el7.noarch
--> Processing Dependency: perl(Module::Metadata) >= 1.000005 for package: perl-Module-Load-Conditional-0.54-3.el7.noarch
--> Processing Dependency: perl(Locale::Maketext::Simple) for package: perl-Module-Load-Conditional-0.54-3.el7.noarch
--> Processing Dependency: perl(Params::Check) for package: perl-Module-Load-Conditional-0.54-3.el7.noarch
---> Package perl-SOAP-WSDL.noarch 0:3.003-1.el7.centos will be installed
--> Processing Dependency: perl(Template) >= 2.18 for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Class::Load) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Apache2::RequestUtil) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Apache2::RequestRec) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Apache2::RequestIO) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Apache2::Log) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(Apache2::Const) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
--> Processing Dependency: perl(APR::Table) for package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch
---> Package perl-Sys-CPU.x86_64 0:0.54-4.el7 will be installed
---> Package perl-Sys-MemInfo.x86_64 0:0.91-7.el7 will be installed
---> Package perl-Sys-Mmap.x86_64 0:0.17-3.el7.centos will be installed
---> Package perl-Sys-Syslog.x86_64 0:0.33-3.el7 will be installed
---> Package perl-URI-Encode.noarch 0:0.09-1.el7 will be installed
---> Package perl-X10.noarch 0:0.03-1 will be installed
--> Processing Dependency: perl(Time::ParseDate) for package: perl-X10-0.03-1.noarch
--> Processing Dependency: perl(Astro::SunTime) for package: perl-X10-0.03-1.noarch
---> Package perl-version.x86_64 3:0.99.07-2.el7 will be installed
---> Package php.x86_64 0:5.4.16-36.3.el7_2 will be installed
--> Processing Dependency: php-cli(x86-64) = 5.4.16-36.3.el7_2 for package: php-5.4.16-36.3.el7_2.x86_64
--> Processing Dependency: php-common(x86-64) = 5.4.16-36.3.el7_2 for package: php-5.4.16-36.3.el7_2.x86_64
---> Package php-gd.x86_64 0:5.4.16-36.3.el7_2 will be installed
--> Processing Dependency: libt1.so.5()(64bit) for package: php-gd-5.4.16-36.3.el7_2.x86_64
---> Package php-mysql.x86_64 0:5.4.16-36.3.el7_2 will be installed
--> Processing Dependency: php-pdo(x86-64) = 5.4.16-36.3.el7_2 for package: php-mysql-5.4.16-36.3.el7_2.x86_64
---> Package vlc-core.x86_64 0:2.2.4-1.el7.centos will be installed
--> Processing Dependency: live555(x86-64) = 2015.10.12 for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libzvbi.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libupnp.so.6()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libtwolame.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libtiger.so.5()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libthreadutil.so.6()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libmpeg2.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libmodplug.so.1()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libminizip.so.1()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libmatroska.so.6()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libmad.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libliveMedia.so.50()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: liblirc_client.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libkate.so.1()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libixml.so.2()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libgroupsock.so.8()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libgme.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libfribidi.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libfaad.so.2()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libebml.so.4()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libdvbpsi.so.10()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libdca.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libchromaprint.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libcddb.so.2()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: liba52.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libUsageEnvironment.so.3()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libSDL_image-1.2.so.0()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
--> Processing Dependency: libBasicUsageEnvironment.so.1()(64bit) for package: vlc-core-2.2.4-1.el7.centos.x86_64
---> Package SDL_image.x86_64 0:1.2.12-11.el7 will be installed
---> Package a52dec.x86_64 0:0.7.4-19.el7.centos will be installed
---> Package faad2-libs.x86_64 1:2.7-6.el7.centos will be installed
---> Package game-music-emu.x86_64 0:0.6.0-5.el7 will be installed
---> Package httpd-tools.x86_64 0:2.4.6-40.el7_2.4 will be installed
---> Package lame-libs.x86_64 0:3.99.5-5.el7.centos will be installed
---> Package libass.x86_64 0:0.13.1-1.el7 will be installed
--> Processing Dependency: libfribidi.so.0()(64bit) for package: libass-0.13.1-1.el7.x86_64
---> Package libcddb.x86_64 0:1.3.2-12.el7 will be installed
---> Package libchromaprint.x86_64 0:1.0-1.el7 will be installed
---> Package libdc1394.x86_64 0:2.2.2-3.el7 will be installed
---> Package libdca.x86_64 0:0.0.5-9.el7.centos will be installed
---> Package libdvbpsi.x86_64 0:1.3.0-1.el7.centos will be installed
---> Package libebml.x86_64 0:1.3.3-3.el7 will be installed
---> Package libkate.x86_64 0:0.4.1-5.el7 will be installed
---> Package libmad.x86_64 0:0.15.1b-17.el7.centos will be installed
---> Package libmatroska.x86_64 0:1.4.1-1.el7 will be installed
---> Package libmodplug.x86_64 1:0.8.8.5-3.el7 will be installed
---> Package libmpeg2.x86_64 0:0.5.1-11.el7.centos will be installed
---> Package libtiger.x86_64 0:0.3.4-7.el7 will be installed
---> Package libupnp.x86_64 0:1.6.19-2.el7 will be installed
---> Package libva.x86_64 0:1.2.1-3.el7 will be installed
---> Package libvdpau.x86_64 0:1.1-2.el7 will be installed
---> Package lirc-libs.x86_64 0:0.9.1a-4.el7 will be installed
---> Package live555.x86_64 0:2015.10.12-1.el7.centos will be installed
---> Package mariadb.x86_64 1:5.5.50-1.el7_2 will be installed
---> Package mod_perl.x86_64 0:2.0.8-10.20140624svn1602105.el7 will be installed
--> Processing Dependency: perl(Linux::Pid) for package: mod_perl-2.0.8-10.20140624svn1602105.el7.x86_64
--> Processing Dependency: perl(BSD::Resource) for package: mod_perl-2.0.8-10.20140624svn1602105.el7.x86_64
---> Package openal-soft.x86_64 0:1.16.0-3.el7 will be installed
---> Package perl-Astro-SunTime.noarch 0:0.01-1 will be installed
---> Package perl-Class-Load.noarch 0:0.20-3.el7 will be installed
--> Processing Dependency: perl(Module::Implementation) >= 0.04 for package: perl-Class-Load-0.20-3.el7.noarch
--> Processing Dependency: perl(Module::Runtime) >= 0.012 for package: perl-Class-Load-0.20-3.el7.noarch
--> Processing Dependency: perl(Package::Stash) >= 0.14 for package: perl-Class-Load-0.20-3.el7.noarch
--> Processing Dependency: perl(Data::OptList) for package: perl-Class-Load-0.20-3.el7.noarch
--> Processing Dependency: perl(Module::Runtime) for package: perl-Class-Load-0.20-3.el7.noarch
--> Processing Dependency: perl(Try::Tiny) for package: perl-Class-Load-0.20-3.el7.noarch
---> Package perl-Class-Std.noarch 0:0.0.9-1.el7.centos will be installed
---> Package perl-Convert-BinHex.noarch 0:1.119-20.el7 will be installed
---> Package perl-Email-Date-Format.noarch 0:1.002-15.el7 will be installed
---> Package perl-IO-Interface.x86_64 0:1.05-15.el7.centos will be installed
---> Package perl-IO-Zlib.noarch 1:1.10-286.el7 will be installed
---> Package perl-Locale-Maketext-Simple.noarch 1:0.21-286.el7 will be installed
--> Processing Dependency: perl(Locale::Maketext) for package: 1:perl-Locale-Maketext-Simple-0.21-286.el7.noarch
---> Package perl-MIME-Types.noarch 0:1.38-2.el7 will be installed
---> Package perl-MailTools.noarch 0:2.12-2.el7 will be installed
--> Processing Dependency: perl(Net::SMTP::SSL) for package: perl-MailTools-2.12-2.el7.noarch
---> Package perl-Module-CoreList.noarch 1:2.76.02-286.el7 will be installed
---> Package perl-Module-Load.noarch 1:0.24-3.el7 will be installed
---> Package perl-Module-Metadata.noarch 0:1.000018-2.el7 will be installed
---> Package perl-Mozilla-CA.noarch 0:20130114-5.el7 will be installed
---> Package perl-Package-Constants.noarch 1:0.02-286.el7 will be installed
---> Package perl-Params-Check.noarch 1:0.38-2.el7 will be installed
---> Package perl-Time-ParseDate.noarch 0:2013.1113-2.el7 will be installed
---> Package php-cli.x86_64 0:5.4.16-36.3.el7_2 will be installed
---> Package php-common.x86_64 0:5.4.16-36.3.el7_2 will be installed
---> Package php-pdo.x86_64 0:5.4.16-36.3.el7_2 will be installed
---> Package schroedinger.x86_64 0:1.0.11-4.el7 will be installed
---> Package soxr.x86_64 0:0.1.2-1.el7 will be installed
---> Package t1lib.x86_64 0:5.1.2-14.el7 will be installed
---> Package twolame-libs.x86_64 0:0.3.13-4.el7.centos will be installed
---> Package x264-libs.x86_64 0:0.148-5.20160118git5c65704.el7.centos will be installed
---> Package x265-libs.x86_64 0:1.8-1.el7.centos will be installed
---> Package xvidcore.x86_64 0:1.3.4-2.el7.centos will be installed
---> Package zvbi.x86_64 0:0.2.35-1.el7 will be installed
---> Package perl-BSD-Resource.x86_64 0:1.29.07-1.el7 will be installed
---> Package perl-Data-OptList.noarch 0:0.107-9.el7 will be installed
--> Processing Dependency: perl(Sub::Install) >= 0.921 for package: perl-Data-OptList-0.107-9.el7.noarch
--> Processing Dependency: perl(Params::Util) for package: perl-Data-OptList-0.107-9.el7.noarch
---> Package perl-Linux-Pid.x86_64 0:0.04-18.el7 will be installed
---> Package perl-Locale-Maketext.noarch 0:1.23-3.el7 will be installed
---> Package perl-Module-Implementation.noarch 0:0.06-6.el7 will be installed
---> Package perl-Module-Runtime.noarch 0:0.013-4.el7 will be installed
---> Package perl-Net-SMTP-SSL.noarch 0:1.01-13.el7 will be installed
---> Package perl-Package-Stash.noarch 0:0.34-2.el7 will be installed
--> Processing Dependency: perl(Package::Stash::XS) >= 0.26 for package: perl-Package-Stash-0.34-2.el7.noarch
--> Processing Dependency: perl(Package::DeprecationManager) for package: perl-Package-Stash-0.34-2.el7.noarch
---> Package perl-Try-Tiny.noarch 0:0.12-2.el7 will be installed
---> Package perl-Package-DeprecationManager.noarch 0:0.13-7.el7 will be installed
--> Processing Dependency: perl(List::MoreUtils) for package: perl-Package-DeprecationManager-0.13-7.el7.noarch
---> Package perl-Package-Stash-XS.x86_64 0:0.26-3.el7 will be installed
---> Package perl-Params-Util.x86_64 0:1.07-6.el7 will be installed
---> Package perl-Sub-Install.noarch 0:0.926-6.el7 will be installed
---> Package perl-List-MoreUtils.x86_64 0:0.33-9.el7 will be installed
--> Finished Dependency Resolution
Error: Package: vlc-core-2.2.4-1.el7.centos.x86_64 (zmrepo)
Requires: libfribidi.so.0()(64bit)
Error: Package: libass-0.13.1-1.el7.x86_64 (zmrepo)
Error: Package: perl-SOAP-WSDL-3.003-1.el7.centos.noarch (zmrepo)
Requires: perl(Template) >= 2.18
Requires: libminizip.so.1()(64bit)
Dependency resolving failed due to missing dependencies.
Some repositories on your system are disabled, but yum can enable them
and search for missing dependencies. This will require downloading
metadata for disabled repositories and may take some time and traffic.
Enable all repositories and try again? [y/N]: n
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
The freee Redhat OS became Fedora after Redhat version 9, so Fedora is the new name of the distro you were once used to. RHEL is the name of Redhat's non-free operating system, which you are using. Because it is not free, I don't have access to it and cannot test against it. Note that Fedora is intended as a development platform, with a 6 month lifecycle, so I don't recommend anyone use that distro for production systems.
All my work is done on CentOS, which is a 100% free binary equivalent to RHEL. The ZoneMinder package is tested weekly on CentOS. If you are looking for a stable distro, intended for production systems, then CentOS is a good choice.
But if you want to try and use RHEl, you need to find what Redhat repository the fribidi, minizip, and perl-Template-Toolkit packages are in. These packages are part of the base CentOS repository, which means there is an equivalent Redhat repository with these packages in them. You just need to figure out the name of the repo and enable it on your system.
I have only received a report from one other person attempting to use RHEL, and that is exactly what he had to do to get ZoneMinder and all its dependencies to install. I just don't remember the name of the repository he had to enable.
