"Add New Monitor" Error
Toko33
Post by Toko33 »
I am running a new Ubuntu install and installed Zoneminder 1.30. (I was running 1.29 until my HDD crashed).
I go to add a monitor and get this error when I click on 'Save' button:
SQL-ERR 'SQLSTATE[HY000]: General error: 1366 Incorrect integer value: '' for column 'ServerId' at row 1', statement was 'insert into Monitors set LinkedMonitors = '', Name = 'Amcrest', ServerId = '', Type = 'Ffmpeg', Function = 'Monitor', Enabled = '1', RefBlendPerc = '6', AlarmRefBlendPerc = '6', AnalysisFPS = '15', MaxFPS = '15', AlarmMaxFPS = '15', Device = '/dev/video0', Channel = '0', Format = '255', Palette = '0', V4LMultiBuffer = '', V4LCapturesPerFrame = '1', Protocol = '', Host = '', Port = '80', RTSPDescribe = '0', LabelFormat = '%N - %d/%m/%y %H:%M:%S', LabelX = '0', LabelY = '0', LabelSize = '1', ImageBufferCount = '50', WarmupCount = '25', PreEventCount = '25', PostEventCount = '25', StreamReplayBuffer = '1000', AlarmFrameCount = '1', EventPrefix = 'Event-', SectionLength = '600', FrameSkip = '0', MotionFrameSkip = '0', AnalysisUpdateDelay = '0', FPSReportInterval = '1000', DefaultView = 'Events', DefaultRate = '100', DefaultScale = '100', WebColour = 'red', Exif = '', SignalCheckColour = '#0000c0', Path = 'rtsp://[removed]:[removed]@[removed]:554/cam/realmonitor?channel=1&subtype=0', Method = 'rtpRtsp', Options = '', Colours = '3', Width = '1280', Height = '960', Orientation = '0', Deinterlacing = '0', Sequence = 1'
I was following these instructions:
I cannot add a monitor. I did not get this error on my 1.29 version install. Please help!
Re: "Add New Monitor" Error
Looks like your database does not have the right permissions. You are running the version of MySQL that came with Ubuntu 14.04?
Dump your database
Run to create a new database:
mysqladmin -uroot -p reload
Toko33
Post by Toko33 »
You are probably right about the SQL server configuration issue.
I think I followed the Ubuntu 14.x instructions when I actually have Ubuntu 16.04 installed. I'm going to go back and reinstall and see if that fixes it.
Sorry
Toko33 wrote:You are probably right about the SQL server configuration issue.
Sorry
Ah, I was wondering if that was the case. There is a bit more to configure MySQL in 16.04. I find it better to use Mariadb and there are instructions in the WIKI to do just that!
