You can use uvcdynctrl -cv to view the available list of commands that you can control the camera with.
For example, for my Orbit AF I get a list of settings I can change:
sudo uvcdynctrl -cv
Listing available controls for device video0:
Brightness
Type : Dword,
Flags : { CAN_READ, CAN_WRITE },
Values : [ 0 .. 255, step size: 1 ],
Default : 128
Contrast
Type : Dword,
Default : 32
Saturation
Type : Dword,
Default : 32
White Balance Temperature, Auto
Type : Boolean,
Values : [ 0 .. 1, step size: 1 ],
Default : 1
Gain
Type : Dword,
Default : 0
Power Line Frequency
Type : Choice,
Values : { 'Disabled'[0], '50 Hz'[1], '60 Hz'[2] },
Default : 2
Type : Dword,
Values : [ 0 .. 10000, step size: 10 ],
Default : 4000
Sharpness
Type : Dword,
Default : 224
Backlight Compensation
Type : Dword,
Values : [ 0 .. 2, step size: 1 ],
Default : 1
Exposure, Auto
Type : Choice,
Values : { 'Manual Mode'[1], 'Aperture Priority Mode'[3] },
Default : 3
Exposure (Absolute)
Type : Dword,
Values : [ 1 .. 10000, step size: 1 ],
Default : 166
Exposure, Auto Priority
Type : Boolean,
Default : 0
Pan (relative)
Type : Dword,
Values : [ -4480 .. 4480, step size: 0 ],
Default : 0
Tilt (relative)
Type : Dword,
Values : [ -1920 .. 1920, step size: 0 ],
Default : 0
Pan Reset
Type : Button,
Values : [ 0 .. 0, step size: 0 ],
Default : 0
Tilt Reset
Type : Button,
Default : 0
Focus
Type : Dword,
Default : 0
LED1 Mode
Type : Choice,
Flags : { CAN_READ, CAN_WRITE, IS_CUSTOM },
Values : { 'Off'[0], 'On'[1], 'Blinking'[2], 'Auto'[3] },
Default : 3
LED1 Frequency
Type : Dword,
Default : 0
Disable video processing
Type : Boolean,
Default : 0
Raw bits per pixel
Type : Dword,
Default : 0
For example:
sudo uvcdynctrl -s 'Tilt (relative)' -- 1280
When going into negative settings, such as -1280, please use -- -1280 so that the negative isn't seen as a command.
I still haven't got a clue how to incorporate this into a script that will allow Zoneminder to control the device, so I would like some help on that. But as far as I can see, no one has posted a "For dummies" guide on how to operate the logitech cameras. Maybe most don't, but it took me a while.
If someone could respond with how to though, I would love to use it, and allow others to see how.
Thanks!
More information about camera operation can be found here:
http://www.sphaero.org/blog:2012:0727_c ... mmand_line
