Page 1 of 1
zmNinja config problem
Posted: Wed Aug 31, 2016 2:19 am
by HarryB
I have a new install of zm 1.30.0 running on fedora 23 on a raspberry pi 3B. Video streaming is working on the zm console. I have configured zmNinja to access the wan side. zmNinja authenticates without throwing errors. I can access various zm console settings and can see the settings on the monitors. However, I get the red question mark when trying to access the video stream from the enabled monitor. php-gd is installed. The API tests all green. I attempted to configure fresh with the wizard, but it failed at the login to the portal even though I am using the same credentials that work when configured manually. I reviewed the log file, but don't see any error.
Please advise.
Re: zmNinja config problem
Posted: Wed Aug 31, 2016 1:10 pm
by asker
1. Can you please post an image of your zmNinja settings screen?
2. You said you configured ZMNinja for WAN --> can you validate WAN works from your desktop browser as well (not LAN)?
Posted: Fri Sep 02, 2016 2:44 am
by HarryB
#2. Accessing the Wan side from a browser, I find that I can get to the console and can get streaming video successfully from the console or the montage page, for example.
#1. These are the values on my zmNinja settings screen:
Server Name: Zm1
Use ZM authentication [checked]
user name: admin
password: **********
ZM portal url: https://<ddns name>:9110/zm
path to cgi-bin: https://<ddns name>:9110/zm/cgi-bin-zm/nph-zms
ZM api url: https://<ddns name>:9110/zm/api
Fallback configuration >
Event server >
password protect [unchecked]
Use SSL [checked]
Keep display on [checked]
Posted: Fri Sep 02, 2016 1:44 pm
by asker
Your cgi-bin is wrong. Did you use the wizard?
replace
with
Posted: Sat Sep 03, 2016 1:00 am
by HarryB
zm/cgi-bin-zm/ doesn't work. I tried the wizard which sets the cgi path to ...<port>/cgi-bin-zm. But that doesn't work either. I always get the red question mark.
Posted: Sat Sep 03, 2016 11:02 am
by asker
1. What is PATH_ZMS set to in ZoneMinder ?
2. When you are viewing live view, please see apache error logs in your ZM instance - what error is it showing? Please post logs.
3. If all fails, please see if I can get access to your instance - even one monitor will do
Posted: Sat Sep 03, 2016 11:22 pm
by HarryB
zmNinja just started working for the first time. I haven't changed anything on the zm machine in the past few days except related to ssh. Did make some changes on the router that should not have affected zmNinja or zm. So, I am a little baffled, but I'll take it.
Thanks a lot for your support. The app looks terrific by the way.
Posted: Sun Sep 04, 2016 12:40 am
by asker
Cool - Glad you got it working!
Please make sure you keep auto-update on. You'll get amazing updates (and occasionally updates that completely break all working functions - what's life if we are not living on the edge?)
Do leave a review on play store if you feel like it.
