Trouble adding camara
jelee
Post by jelee »
Have some problems to add network cameras to Zoneminder (No camera images)
VLC player grabs the stream neatly;
rtsp://admin:admin@192.168.1.10:554/user=admin_password=admin_channel=1_stream=0.sdp?real_stream
Camara brand:
Escam Snail QD500 720P 1MP
camara specs:
Model QD500
Camera
Image Sensor: 1/4" Progressive Scan CMOS
Effective Pixels: 1280(H)x720(V)
Scanning System: Progressive
Electronic Shutter Speed: Auto/Manual, 1/3~1/10000s
Min. Illumination Color: 0. 1Lux, B/W: 0.01Lux ; 0Lux(IR on)
S/N Ratio: >50dB
Camera Features
Max. IR LEDs Length Φ5 24pcs IR Leds, 10m IR Range
Play and Plug (P2P) Yes
Day/Night Auto(ICR) / Color / B/W
Backlight Compensation BLC
White Balance Auto
Gain Control Auto/Manual
Noise Reduction 2D
Privacy Masking N/A
Lens
Focal Length: 3.6mm
Max Aperture: F1.6
Angle of View: 62.2°
Mount Type: MTV mount (Interchangeable Lens)
Video
Compression H.264 / MJPEG
Frame Rate Main Stream HD 720P (1280 x 720) 25fps
Sub Stream VGA 640 x 360 25FPS
Bit Rate 32-4096Kbps,Supports CBR/VBR
Re: Trouble adding camara
Hard to tell without seeing the contents of your zoneminder log.
Do the following:
- restart zoneminder
- wait and watch the log. do not click on anything. Do NOT try to open a live view.
- You will eventually see something like "Capturing at x.xx fps" or you will begin to see error messages. When you see this, copy everything you see from the moment zoneminder was started to just after the error(s) occur. We need to see all of it.
We also need to know what distro you are using and how you installed zoneminder.
jelee
Post by jelee »
Logs: http://dumptext.com/tYeQNEtr
Lubuntu 14.04 - Zoneminder 1.29.0
The fact that you can see "Capturing at 25.00 fps" in the logs means the backend is working for monitor #6, which means you have programmed that camera correctly.
This also means that the problem is with your Apache configuration as it relates to PATH_ZMS. This is also highly documented. You should review the Wiki documentation for installing ZoneMinder on Ubuntu 14.04, particularly the step that talks about setting PATH_ZMS, but you should also review all the other steps to make sure you did not miss anything else.
