Page 1 of 1
Blank index.php after upgrade to Ubuntu 16.04
Posted: Sat Sep 10, 2016 4:43 pm
by Steveearle86
Hi all,
I have been running Zoneminder 1.29 on Ubuntu 15.10 with no problems. Today I upgraded my Ubuntu installation to 16.04 using the following commands
apt-get update
apt-get upgrade
apt-get dist-upgrade
sudo apt-get install update-manager-core
sudo do-release-upgrade
Once the system had finally done the upgrade and restarted, when I navigate to 127.0.0.1/zm on the Ubuntu PC ZM is installed on I get a blank page. The same is true when substituting the 127.0.0.1 with the server's IP from a different machine.
When I navigate to the default Apache page, I get the usual default page.
I checked the zoneminder service and it is running. Restarted it and still nothing.
After a bit of Googling I tried the following fixes:
rm /etc/mysql/my.cnf
cp /etc/mysql/mysql.conf.d/mysqld.cnf /etc/mysql/my.cnf
gedit /etc/mysql/my.cnf
added the following line at 32
restarted the PC and still nothing
tried the fix
here and set short_open_tag to on
but still nothing after a reboot.
I can see from the directory where I store my images that they are still being written so zoneminder itself is running as expected therefore I think it's likely to be something on the Apache side.
Can anyone help?
Re: Blank index.php after upgrade to Ubuntu 16.04
Posted: Sat Sep 10, 2016 8:51 pm
by SteveGilvarry
OK so assuming apache config is still OK and points to where php files live, and reloaded
Maybe check the wiki
https://wiki.zoneminder.com/Ubuntu has some notes on upgrading.
I would also be looking at php install status if something between php5 and php7, check apache php module is enabled etc.
Posted: Sun Sep 11, 2016 1:31 am
by bbunge
Posted: Sun Sep 18, 2016 5:16 pm
by Steveearle86
Hi both,
Thanks for your replies. I looked at the
Ubuntu 15.10 with ZM 1.29.0 from the PPA to Ubuntu 16.04 section on the Common Issues with Zoneminder Installation on Ubuntu link and carried out the steps to no avail. I can confirm my PHP version according to
is PHP 5.6.11-1ubuntu3.4 (cli).
Also it doesnt look like the apache php modules is enabled :
apache2ctl -M | sort
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
access_compat_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
cgi_module (shared)
core_module (static)
deflate_module (shared)
dir_module (shared)
env_module (shared)
filter_module (shared)
http_module (static)
Loaded Modules:
log_config_module (static)
logio_module (static)
mime_module (shared)
mpm_prefork_module (shared)
negotiation_module (shared)
rewrite_module (shared)
setenvif_module (shared)
so_module (static)
status_module (shared)
unixd_module (static)
version_module (static)
watchdog_module (static)
Is this a PHP issue or an Apache issue!? I could retry upgrading PHP if that would help?
Posted: Sun Sep 18, 2016 7:49 pm
by bbunge
16.04 should install php7 and that is what you need to look for. Those procedures were done for the initial release of 16.04 and I have not rerun them with 16.04-1 so something could have changed. You might try to force a reinstall of Zoneminder, manually install php7 and upgrade the ZM database. see
https://wiki.zoneminder.com/Common_Issu ... untu_16.04
Posted: Mon Oct 10, 2016 2:46 pm
by rkozsan
I am also seeing the same thing as Steveearle86 after upgrading to 16.04.1. Checked all of the same things -no luck.
Mine install is on PHP 7.
Like Steveearle86, apache did not have a lib php module installed/active... turns out, the install of libapache2-mod-php / libapache2-mod-php7.0 fails.
Anyone seen this?
Posted: Mon Oct 10, 2016 3:20 pm
by rkozsan
This provided valuable clues to the apache php module install issue:
https://bugs.launchpad.net/ubuntu/+sour ... ug/1576334
Zoneminder index.php still blank (<body> section empty)
Posted: Wed Oct 12, 2016 12:14 pm
by knight-of-ni
Steveearle86 wrote:Hi both,
Like bbunge said earlier, this right here is your first problem. During the upgrade to Ubuntu 16.04, your php should have been upgraded to php 7, but you've shown us that is was not. Fixing this should be your first priority. The zoneminder documentation in the wiki is not going to help you unless you have the same version of php in which the documentation was written.
Once that you've got the correct version of php on your machine, then you need to look at the contents of your Apache log files for errors if the web console is still blank.
Posted: Sun Feb 26, 2017 1:42 pm
by Steveearle86
Hi all,
Just a note, I thought it easier to do a complete reinstall of Ubuntu and ZM which has fixed the issue. This also fixed some API issues I was having and the system also seems way more stable!
