I am putting together a shopping list for the computer I will install ZM on. Will this system have enough punch?
AM1 system with a AMD Athlon 5350 Kabini quad core.
2 TB video drive. I will have a small SSD for the system.
A mix of 4-5 of the following cameras. TRENDnet TV-IP320PI and TV-IP420P.
I hate having a system heating my basement without enough to do. Should I get a beefier system?
McGeek
Computer HW
Re: Computer HW
Recording video to a hard drive does not take a lot of beef. In general, here is what takes cpu cycles:
Old analog cameras do not have any motion detection built-in. All motion detection had to be done by your recording software.
That being said... IP cameras typically do the encoding and motion detection for you. Expensive, high-quality IP cameras do motion detection very well. (ZM has a script to read camera's MD). Cheap IP cameras typically do not do motion detection accurately. (use ZM for MD with Trendnet cameras
I have no experience with Trendnet cameras, but since they are doing the H.254 encoding for you just need to record that (15 fps is PLENTY). Use the substream m-Jpeg at a lower frame rate just for the motion detect.
See this post on using an Intel NUC with an atom processor for a recorder:
viewtopic.php?f=14&t=22542&p=85815
- Encoding Video (to H.264 or M-Jpeg)
- Motion Detection
