Manually add a UDP Onvif Camera with no username - IZTouch IZSP-012
nagmier
Post by nagmier »
I have a IZTouch IZSP-012 that I can get to come up in iSpy but Zoneminder is giving me an internal error, I'm assuming because I'm not entering a username... In iSpy I am able to see the stream via with these options:
rtsp://:password@192.168.xxx.staticip:554/onvif1
When RTSP Mode is set to UDP I am able to view the stream normally
TCP, UDP Multicast and HTTP Fail
Is there a script I can run or a database I can edit manually to add a new entry or is this something that is inherently screwed up with this device and I should move on?
Re: Manually add a UDP Onvif Camera with no username - IZTouch IZSP-012
